[postgis-users] Gentoo/Debian Packages using 1.1.0CVS?
david techer
davidtecher at yahoo.fr
Thu Sep 15 04:30:14 PDT 2005
Hi Sandro
Hum!! U're right!
Since I'm not responsible for Ebuild Gentoo but Gerald does...
I have look for Debian and Win32 for PostGIS.
Ok...!
I will wait for Gerald to be here and to have a moment with him...
strk at refractions.net wrote:
>David, I understand the will to switch to 1.1.X, but users
>are reporting packages to be versioned 1.0.X ! Also no 1.1.X
>release is out yet, distributing packages for it would increase
>confusion (what version would users be referring to when saying
>1.1.0CVS ?).
>I suggest you clearly state the package contains a CVS snapshot and
>patch the Version.config file to include update time in version
>(like 1.1.0CVS-20050915), using same naming convention for the package
>itself.
>--strk;
>On Thu, Sep 15, 2005 at 12:52:37PM +0200, david techer wrote:
>>Hi Mark,
>>I think my friend Gerald FENOY will answer U as soon as possible.
>>I hope I don't make mistake...So excuse-me I'll say something wrong
>>So Why using 1.1.0CVS instead of 1.0.X?
>>Because 1.1.0CVS, as U know doesn't require PostgreSQL Sources...
>>On Gentoo If U already have PostgerSQL installed with example thanks to
>>emerge command
>>when U want to compil/build postgis 1.0.X U will have to download again
>>PostgreSQL sources
>>and to compil it again.
>>(emerge requires it automatically..) before compiling PostGIS.
>>So it seems not to be interesting to have to compil PostgreSQL one more
>>times if U have a binary distrib already installed...This is the technic
>>from series 1.0.X of PostGIS
>>Whereas with 1.1.0CVS, PostGIS doesn't need PostgreSQL sources..So in
>>Gentoo, emerge only PostGIS 1.1.0 CVS
>>by CVS or tarball....U have to compil it and install it. It doesn't
>>require a second PostgerSQL download, compil, install and so on....
>>By the way since Gerald FENOY automatically does a postgis 1.1.0 cvs
>>tarball
>>when he want to build a PosTGIS ebuild for Gentoo...
>>I hope what I said is enough understandable :-)
>>Regards David
>>Mark Cave-Ayland wrote:
>>>Hi everyone,
>>>Just looking at some of the reports coming into the mailing list, (in
>>>particular Nicol's and Christo's), it appears that the Gentoo and Debian
>>>builds are using PostGIS 1.1.0CVS instead of the latest 1.0.x release. Is
>>>there any reason why this is so? Would anyone like to volunteer to look
>>>after these packages and make sure they reflect the latest 1.0.x stable
>>>releases?
>>>Kind regards,
>>>Mark.
>>>WebBased Ltd
>>>South West Technology Centre
>>>Tamar Science Park
>>>Plymouth
>>>PL6 8BT
>>>T: +44 (0)1752 791021
>>>F: +44 (0)1752 791023
>>>W: http://www.webbased.co.uk
>>>_______________________________________________
>>>postgis-users mailing list
>>>postgis-users at postgis.refractions.net
>>>http://postgis.refractions.net/mailman/listinfo/postgis-users
>>___________________________________________________________________________
>>Appel audio GRATUIT partout dans le monde avec le nouveau Yahoo! Messenger
>>Téléchargez cette version sur http://fr.messenger.yahoo.com
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050915/53e9f260/attachment.html>
