[postgis-users] Gentoo/Debian Packages using 1.1.0CVS?
strk at refractions.net strk at refractions.net
Thu Sep 15 02:15:28 PDT 2005
David, I understand the will to switch to 1.1.X, but users
are reporting packages to be versioned 1.0.X ! Also no 1.1.X
release is out yet, distributing packages for it would increase
confusion (what version would users be referring to when saying
1.1.0CVS ?).
I suggest you clearly state the package contains a CVS snapshot and
patch the Version.config file to include update time in version
(like 1.1.0CVS-20050915), using same naming convention for the package
itself.
--strk;
On Thu, Sep 15, 2005 at 12:52:37PM +0200, david techer wrote:
> Hi Mark,
> I think my friend Gerald FENOY will answer U as soon as possible.
> I hope I don't make mistake...So excuse-me I'll say something wrong
> So Why using 1.1.0CVS instead of 1.0.X?
> Because 1.1.0CVS, as U know doesn't require PostgreSQL Sources...
> On Gentoo If U already have PostgerSQL installed with example thanks to
> emerge command
> when U want to compil/build postgis 1.0.X U will have to download again
> PostgreSQL sources
> and to compil it again.
> (emerge requires it automatically..) before compiling PostGIS.
> So it seems not to be interesting to have to compil PostgreSQL one more
> times if U have a binary distrib already installed...This is the technic
> from series 1.0.X of PostGIS
> Whereas with 1.1.0CVS, PostGIS doesn't need PostgreSQL sources..So in
> Gentoo, emerge only PostGIS 1.1.0 CVS
> by CVS or tarball....U have to compil it and install it. It doesn't
> require a second PostgerSQL download, compil, install and so on....
> By the way since Gerald FENOY automatically does a postgis 1.1.0 cvs
> tarball
> when he want to build a PosTGIS ebuild for Gentoo...
> I hope what I said is enough understandable :-)
> Regards David
> Mark Cave-Ayland wrote:
> >Hi everyone,
> >Just looking at some of the reports coming into the mailing list, (in
> >particular Nicol's and Christo's), it appears that the Gentoo and Debian
> >builds are using PostGIS 1.1.0CVS instead of the latest 1.0.x release. Is
> >there any reason why this is so? Would anyone like to volunteer to look
> >after these packages and make sure they reflect the latest 1.0.x stable
> >releases?
> >Kind regards,
> >Mark.
> >WebBased Ltd
> >South West Technology Centre
> >Tamar Science Park
> >Plymouth
> >PL6 8BT
> >T: +44 (0)1752 791021
> >F: +44 (0)1752 791023
> >W: http://www.webbased.co.uk
> >_______________________________________________
> >postgis-users mailing list
> >postgis-users at postgis.refractions.net
> >http://postgis.refractions.net/mailman/listinfo/postgis-users
> ___________________________________________________________________________
> Appel audio GRATUIT partout dans le monde avec le nouveau Yahoo! Messenger
> Téléchargez cette version sur http://fr.messenger.yahoo.com
