[postgis-users] importing shape files nightmare!
christomec christo at mecola.com
Thu Sep 15 07:27:59 PDT 2005
I'm sorry, my mistake. I thought I had the use flags set in a file
somewhere, but that was not the case. I'll try emerging again. Could this
be why I'm still experiencing the same problems?
> Well ....
> I've just downloaded the lastest 1.0.4 version of postgis from
> postgis.org and I see that the shp2pgsql.c as the same date
> (2005/08/29 22:36:14) so the problem couldn't came from here I think.
> Concerning the geos and proj support you must set proj and geos in
> your USE flags, for more support information use emerge -pv postgis,
> here you've see all the support (red are supports enabled and  blue
> are those disabled). To simplify you must reemerge postgis with the
> specified flags, for example you could simply use this command line :
> USE="proj geos" emerge -v postgis
> (or -pv to ensure that you'll effectively use geos and proj support).
> Hope that help.
> Le 15 sept. 05 à 15:37, christomec a écrit :
>> I have now emerged postgis-1.0.4_p20050914.ebuild, but it seems
>> that the
>> original problems weren't solved. Trying to import a shape file still
>> fails.
>> trying:
>> shp2pgsql -c /tmp/streets.shp streets | psql -d dbname
>> ERROR:  unterminated quoted string at or near
>> "'010500000001000000010200000005000000D670917BBAA6394034BDC458A6E940C0
>> 2C9ACE4E06A73940A911FA997AE940C0BEF561BD51A7394"
>> at character 292
>> LINE 1: ...TRAND','0687-0890-000','0687-0890-000_6TH
>> AVENUE','010500000...
>> and trying:
>> shp2pgsql -D /tmp/streets.shp streets dbname > /tmp/streets.sql
>> Shapefile type: Arc
>> Postgis type: MULTILINESTRING[2]
>> Segmentation fault
>> shp2pgsql
>> RCSID: $Id: shp2pgsql.c,v 1.96 2005/08/29 22:36:25 strk Exp $
>> select postgis_full_version();
>> POSTGIS="1.1.0CVS" USE_STATS DBPROC="0.3.1" RELPROC="0.3.1"
>> Where is geos and proj4?
>> cat /etc/portage/package.keywords
>> dev-db/postgis ~x86
>> sci-libs/proj ~x86
>> sci-libs/geos ~x86
>>> Attached is a patch to bring shp2pgsql.c from Revision 1.91
>>> to Revision 1.96 (the one shipped with PostGIS 1.0.4).
>>> If you don't have the sources that's ... well ... sad :(
>>> You can still download latest release sources (1.0.4),
>>> run make in the loader/ directory and replace your dumper/loader
>>> with the newly created ones.
>>> .. you can read by the end of the patch all changes
>>> in shp2pgsql since 1.91 ...
>>> --strk;
>>> On Thu, Sep 15, 2005 at 12:28:25PM +0200, christomec wrote:
>>>> I get:
>>>> RCSID: $Id: shp2pgsql.c,v 1.91 2005/07/04 09:47:03 strk Exp $
>>>> Is there a way of just fixing the shp2pgsql without having to
>>>> re-emerging
>>>> postgis?
>>>>> On Thu, Sep 15, 2005 at 11:58:29AM +0200, strk at refractions.net
>>>>> wrote:
>>>>>> On Thu, Sep 15, 2005 at 11:52:08AM +0200, christomec wrote:
>>>>>>> So is POSTGIS="1.1.0CVS" is in actual fact 1.0.3?
>>>>>> Might be, the 1.1 and 1.0 are two different branches in CVS,
>>>>>> and 1.1.0CVS is there since about 1.0.0 is out... there's no
>>>>>> easy way to tell which version of the code 1.1.0CVS is.
>>>>>> Since this is a bug with pgsql2shp what you should look at
>>>>>> is RCSID from it. It is shown running pgsql2shp w/out arguments.
>>>>> Oops.. sorry, it's shp2pgsql (the loader), NOT pgsql2shp (the
>>>>> dumper).
>>>>> The RCSID is still shown when called w/out args
>>>>> --strk;
>>>>> _______________________________________________
>>>>> postgis-users mailing list
>>>>> postgis-users at postgis.refractions.net
>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>> !DSPAM:43294f2574687751170862!
> !DSPAM:43297c7440031236047141!
