[postgis-users] importing shape files nightmare!
Gérald Fenoy djayweb at djayux.net
Thu Sep 15 08:16:52 PDT 2005
Could you try to log two postgis compilation and send their here ?
I explain myself, to solve this problem I think that you could
download the postgis-1.0.4_p20050914.tar.gz tarball, then compile and
install it by hand (log the whole process and the result for your
importation). If that works then you've maybe add too much
compilation optimizations options (could you give what optimizations
you've used ?).
Then reemerge the postgis-1.0.4_p20050914.ebuild and log the whole
proccess (emerge -v postgis >& /tmp/emerge.log, rerun your
importation test.
Then I see what could I do to solve this, comparing both files.
Le 15 sept. 05 à 17:04, christomec a écrit :
> Unfotunetaly the data belong to a client and is also regarded as
> sensitive
> data.
> What I can't understand is the that it works on the suse installation
> (source) and not on the gentoo (emerge).
> suse:
> select version();
> PostgreSQL 8.0.3 on i686-pc-linux-gnu, compiled by GCC gcc (GCC) 3.3.5
> 20050117 (prerelease) (SUSE Linux)
> select postgis_full_version();
> POSTGIS="1.0.3" PROJ="Rel. 4.4.8, 3 May 2004" USE_STATS DBPROC="0.3.0"
> RELPROC="0.3.0"
> gentoo: [new install: postgis-1.0.4_p20050914.ebuild]
> select version();
> i686-pc-linux-gnu-gcc (GCC) 3.3.6 (Gentoo 3.3.6, ssp-3.3.6-1.0,
> pie-8.7.8)
> POSTGIS="1.1.0CVS" GEOS="2.1.4" PROJ="Rel. 4.4.9, 29 Oct 2004"
> USE_STATS
> DBPROC="0.3.1" RELPROC="0.3.1"
> gentoo: [previous install: postgis-1.0.1_p20050727-r1.ebuild]
> select version();
> pie-8.7.8)
> USE_STATS
>> Hi strk,
>> do you mean there is still a problem with the
>> postgis-1.0.4_p20050914.tar.gz tarball ?
>> Christo, please could you send here the problematic shapefile
>> please ? We could test it with 1.1.0CVS and the official 1.0.4 one.
>> Le 15 sept. 05 à 16:34, strk at refractions.net a écrit :
>>> On Thu, Sep 15, 2005 at 04:27:59PM +0200, christomec wrote:
>>>> I'm sorry, my mistake. I thought I had the use flags set in a file
>>>> somewhere, but that was not the case. I'll try emerging again.
>>>> Could this
>>>> be why I'm still experiencing the same problems?
>>> GEOS and PROJ4 have nothing to do with loading shapefiles.
>>> Why don't you get the sources instead of fighting with package
>>> managers ? Belive me, that's where the meat is.
>>> --strk;
>>>>> Well ....
>>>>> I've just downloaded the lastest 1.0.4 version of postgis from
>>>>> postgis.org and I see that the shp2pgsql.c as the same date
>>>>> (2005/08/29 22:36:14) so the problem couldn't came from here I
>>>>> think.
>>>>> Concerning the geos and proj support you must set proj and geos in
>>>>> your USE flags, for more support information use emerge -pv
>>>>> postgis,
>>>>> here you've see all the support (red are supports enabled and
>>>>> blue
>>>>> are those disabled). To simplify you must reemerge postgis with
>>>>> the
>>>>> specified flags, for example you could simply use this command
>>>>> line :
>>>>> USE="proj geos" emerge -v postgis
>>>>> (or -pv to ensure that you'll effectively use geos and proj
>>>>> support).
>>>>> Hope that help.
>>>>> Le 15 sept. 05 à 15:37, christomec a écrit :
>>>>>> I have now emerged postgis-1.0.4_p20050914.ebuild, but it seems
>>>>>> that the
>>>>>> original problems weren't solved. Trying to import a shape file
>>>>>> still
>>>>>> fails.
>>>>>> trying:
>>>>>> shp2pgsql -c /tmp/streets.shp streets | psql -d dbname
>>>>>> ERROR:  unterminated quoted string at or near
>>>>>> "'010500000001000000010200000005000000D670917BBAA6394034BDC458A6E
>>>>>> 94
>>>>>> 0C0
>>>>>> 2C9ACE4E06A73940A911FA997AE940C0BEF561BD51A7394"
>>>>>> at character 292
>>>>>> LINE 1: ...TRAND','0687-0890-000','0687-0890-000_6TH
>>>>>> AVENUE','010500000...
>>>>>> and trying:
>>>>>> shp2pgsql -D /tmp/streets.shp streets dbname > /tmp/streets.sql
>>>>>> Shapefile type: Arc
>>>>>> Postgis type: MULTILINESTRING[2]
>>>>>> Segmentation fault
>>>>>> shp2pgsql
>>>>>> RCSID: $Id: shp2pgsql.c,v 1.96 2005/08/29 22:36:25 strk Exp $
>>>>>> POSTGIS="1.1.0CVS" USE_STATS DBPROC="0.3.1" RELPROC="0.3.1"
>>>>>> Where is geos and proj4?
>>>>>> cat /etc/portage/package.keywords
>>>>>> dev-db/postgis ~x86
>>>>>> sci-libs/proj ~x86
>>>>>> sci-libs/geos ~x86
>>>>>>> Attached is a patch to bring shp2pgsql.c from Revision 1.91
>>>>>>> to Revision 1.96 (the one shipped with PostGIS 1.0.4).
>>>>>>> If you don't have the sources that's ... well ... sad :(
>>>>>>> You can still download latest release sources (1.0.4),
>>>>>>> run make in the loader/ directory and replace your dumper/loader
>>>>>>> with the newly created ones.
>>>>>>> .. you can read by the end of the patch all changes
>>>>>>> in shp2pgsql since 1.91 ...
>>>>>>> --strk;
>>>>>>> On Thu, Sep 15, 2005 at 12:28:25PM +0200, christomec wrote:
>>>>>>>> I get:
>>>>>>>> RCSID: $Id: shp2pgsql.c,v 1.91 2005/07/04 09:47:03 strk Exp $
>>>>>>>> Is there a way of just fixing the shp2pgsql without having to
>>>>>>>> re-emerging
>>>>>>>> postgis?
>>>>>>>>> On Thu, Sep 15, 2005 at 11:58:29AM +0200, strk at refractions.net
>>>>>>>>> wrote:
>>>>>>>>>> On Thu, Sep 15, 2005 at 11:52:08AM +0200, christomec wrote:
>>>>>>>>>>> So is POSTGIS="1.1.0CVS" is in actual fact 1.0.3?
>>>>>>>>>> Might be, the 1.1 and 1.0 are two different branches in CVS,
>>>>>>>>>> and 1.1.0CVS is there since about 1.0.0 is out... there's no
>>>>>>>>>> easy way to tell which version of the code 1.1.0CVS is.
>>>>>>>>>> Since this is a bug with pgsql2shp what you should look at
>>>>>>>>>> is RCSID from it. It is shown running pgsql2shp w/out
>>>>>>>>>> arguments.
>>>>>>>>> Oops.. sorry, it's shp2pgsql (the loader), NOT pgsql2shp (the
>>>>>>>>> dumper).
>>>>>>>>> The RCSID is still shown when called w/out args
>>>>>>>>> --strk;
>>>>>>>>> _______________________________________________
>>>>>>>>> postgis-users mailing list
>>>>>>>>> postgis-users at postgis.refractions.net
>>>>>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>>>> !DSPAM:43297c7440031236047141!
>> !DSPAM:43298a29104494037015152!
