[postgis-users] importing shape files nightmare!
christomec
christo at mecola.com
Fri Sep 16 03:49:31 PDT 2005
Problem solved.
We downloaded & installed the source:
postgresql-8.0.3.tar.gz
postgis-1.0.4.tar.gz
proj-4.4.9.tar.gz
geos-2.1.4.tar.bz2
Still experiencing the same issues, then we installed:
postgis-1.0.3.tar.gz
And then it worked.
No using:
RCSID: $Id: shp2pgsql.c,v 1.88.2.5 2005/07/27 02:47:06 strk Exp $
Was using: [both installed by prvious emerges, both giving the same problem]
RCSID: $Id: shp2pgsql.c,v 1.96 2005/08/29 22:36:25 strk Exp $
RCSID: $Id: shp2pgsql.c,v 1.91 2005/07/04 09:47:03 strk Exp $
So it seems that postgis 1.0.4 has the problem and not 1.0.3.
Thanx for all the help!
> Could you try to log two postgis compilation and send their here ?
> I explain myself, to solve this problem I think that you could
> download the postgis-1.0.4_p20050914.tar.gz tarball, then compile and
> install it by hand (log the whole process and the result for your
> importation). If that works then you've maybe add too much
> compilation optimizations options (could you give what optimizations
> you've used ?).
> Then reemerge the postgis-1.0.4_p20050914.ebuild and log the whole
> proccess (emerge -v postgis >& /tmp/emerge.log, rerun your
> importation test.
> Then I see what could I do to solve this, comparing both files.
> Le 15 sept. 05 à 17:04, christomec a écrit :
>> Unfotunetaly the data belong to a client and is also regarded as
>> sensitive
>> data.
>> What I can't understand is the that it works on the suse installation
>> (source) and not on the gentoo (emerge).
>> suse:
>> select version();
>> PostgreSQL 8.0.3 on i686-pc-linux-gnu, compiled by GCC gcc (GCC) 3.3.5
>> 20050117 (prerelease) (SUSE Linux)
>> select postgis_full_version();
>> POSTGIS="1.0.3" PROJ="Rel. 4.4.8, 3 May 2004" USE_STATS DBPROC="0.3.0"
>> RELPROC="0.3.0"
>> gentoo: [new install: postgis-1.0.4_p20050914.ebuild]
>> select version();
>> i686-pc-linux-gnu-gcc (GCC) 3.3.6 (Gentoo 3.3.6, ssp-3.3.6-1.0,
>> pie-8.7.8)
>> POSTGIS="1.1.0CVS" GEOS="2.1.4" PROJ="Rel. 4.4.9, 29 Oct 2004"
>> USE_STATS
>> DBPROC="0.3.1" RELPROC="0.3.1"
>> gentoo: [previous install: postgis-1.0.1_p20050727-r1.ebuild]
>> select version();
>> pie-8.7.8)
>> USE_STATS
>>> Hi strk,
>>> do you mean there is still a problem with the
>>> postgis-1.0.4_p20050914.tar.gz tarball ?
>>> Christo, please could you send here the problematic shapefile
>>> please ? We could test it with 1.1.0CVS and the official 1.0.4 one.
>>> Le 15 sept. 05 à 16:34, strk at refractions.net a écrit :
>>>> On Thu, Sep 15, 2005 at 04:27:59PM +0200, christomec wrote:
>>>>> I'm sorry, my mistake. I thought I had the use flags set in a file
>>>>> somewhere, but that was not the case. I'll try emerging again.
>>>>> Could this
>>>>> be why I'm still experiencing the same problems?
>>>> GEOS and PROJ4 have nothing to do with loading shapefiles.
>>>> Why don't you get the sources instead of fighting with package
>>>> managers ? Belive me, that's where the meat is.
>>>> --strk;
>>>>>> Well ....
>>>>>> I've just downloaded the lastest 1.0.4 version of postgis from
>>>>>> postgis.org and I see that the shp2pgsql.c as the same date
>>>>>> (2005/08/29 22:36:14) so the problem couldn't came from here I
>>>>>> think.
>>>>>> Concerning the geos and proj support you must set proj and geos in
>>>>>> your USE flags, for more support information use emerge -pv
>>>>>> postgis,
>>>>>> here you've see all the support (red are supports enabled and
>>>>>> blue
>>>>>> are those disabled). To simplify you must reemerge postgis with
>>>>>> the
>>>>>> specified flags, for example you could simply use this command
>>>>>> line :
>>>>>> USE="proj geos" emerge -v postgis
>>>>>> (or -pv to ensure that you'll effectively use geos and proj
>>>>>> support).
>>>>>> Hope that help.
>>>>>> Le 15 sept. 05 à 15:37, christomec a écrit :
>>>>>>> I have now emerged postgis-1.0.4_p20050914.ebuild, but it seems
>>>>>>> that the
>>>>>>> original problems weren't solved. Trying to import a shape file
>>>>>>> still
>>>>>>> fails.
>>>>>>> trying:
>>>>>>> shp2pgsql -c /tmp/streets.shp streets | psql -d dbname
>>>>>>> ERROR: unterminated quoted string at or near
>>>>>>> "'010500000001000000010200000005000000D670917BBAA6394034BDC458A6E
>>>>>>> 94
>>>>>>> 0C0
>>>>>>> 2C9ACE4E06A73940A911FA997AE940C0BEF561BD51A7394"
>>>>>>> at character 292
>>>>>>> LINE 1: ...TRAND','0687-0890-000','0687-0890-000_6TH
>>>>>>> AVENUE','010500000...
>>>>>>> and trying:
>>>>>>> shp2pgsql -D /tmp/streets.shp streets dbname > /tmp/streets.sql
>>>>>>> Shapefile type: Arc
>>>>>>> Postgis type: MULTILINESTRING[2]
>>>>>>> Segmentation fault
>>>>>>> shp2pgsql
>>>>>>> POSTGIS="1.1.0CVS" USE_STATS DBPROC="0.3.1" RELPROC="0.3.1"
>>>>>>> Where is geos and proj4?
>>>>>>> cat /etc/portage/package.keywords
>>>>>>> dev-db/postgis ~x86
>>>>>>> sci-libs/proj ~x86
>>>>>>> sci-libs/geos ~x86
>>>>>>>> Attached is a patch to bring shp2pgsql.c from Revision 1.91
>>>>>>>> to Revision 1.96 (the one shipped with PostGIS 1.0.4).
>>>>>>>> If you don't have the sources that's ... well ... sad :(
>>>>>>>> You can still download latest release sources (1.0.4),
>>>>>>>> run make in the loader/ directory and replace your dumper/loader
>>>>>>>> with the newly created ones.
>>>>>>>> .. you can read by the end of the patch all changes
>>>>>>>> in shp2pgsql since 1.91 ...
>>>>>>>> --strk;
>>>>>>>> On Thu, Sep 15, 2005 at 12:28:25PM +0200, christomec wrote:
>>>>>>>>> I get:
>>>>>>>>> Is there a way of just fixing the shp2pgsql without having to
>>>>>>>>> re-emerging
>>>>>>>>> postgis?
>>>>>>>>>> On Thu, Sep 15, 2005 at 11:58:29AM +0200, strk at refractions.net
>>>>>>>>>> wrote:
>>>>>>>>>>> On Thu, Sep 15, 2005 at 11:52:08AM +0200, christomec wrote:
>>>>>>>>>>>> So is POSTGIS="1.1.0CVS" is in actual fact 1.0.3?
>>>>>>>>>>> Might be, the 1.1 and 1.0 are two different branches in CVS,
>>>>>>>>>>> and 1.1.0CVS is there since about 1.0.0 is out... there's no
>>>>>>>>>>> easy way to tell which version of the code 1.1.0CVS is.
>>>>>>>>>>> Since this is a bug with pgsql2shp what you should look at
>>>>>>>>>>> is RCSID from it. It is shown running pgsql2shp w/out
>>>>>>>>>>> arguments.
>>>>>>>>>> Oops.. sorry, it's shp2pgsql (the loader), NOT pgsql2shp (the
>>>>>>>>>> dumper).
>>>>>>>>>> The RCSID is still shown when called w/out args
>>>>>>>>>> --strk;
>>>>>>>>>> _______________________________________________
>>>>>>>>>> postgis-users mailing list
>>>>>>>>>> postgis-users at postgis.refractions.net
>>>>>>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>> !DSPAM:43298a29104494037015152!
> !DSPAM:432990ca131573838667129!
