[postgis-users] importing shape files nightmare!
Gérald Fenoy djayweb at djayux.net
Fri Sep 16 04:30:31 PDT 2005
strange news ... but it make me thinking that the ebuild is not the
problem.
Yeasterday, after your mails, I've decided to make a new ebuild
called postgis-1.0.4_p20050915.ebuild which is available as always on
01Map.net/gentoo/dev-db/postgis .
This ebuild use the newest cvs version which contain some
modifications which are listed on the official site : http://
postgis.refractions.net/CVS.txt (all modifications made on 2005/09/15
are used in this correponding tarball).
It's the version corresponding to the official 1.0.4 one.
Testers need.
ps: this will not solve your problem cause it's version 1.0.4 but
could you test it and then send us a strace (or some gdb ouotput) of
your shp2pgsql command ?
Le 16 sept. 05 à 12:49, christomec a écrit :
> Problem solved.
> We downloaded & installed the source:
> postgresql-8.0.3.tar.gz
> postgis-1.0.4.tar.gz
> proj-4.4.9.tar.gz
> geos-2.1.4.tar.bz2
> Still experiencing the same issues, then we installed:
> postgis-1.0.3.tar.gz
> And then it worked.
> No using:
> RCSID: $Id: shp2pgsql.c,v 1.88.2.5 2005/07/27 02:47:06 strk Exp $
> Was using: [both installed by prvious emerges, both giving the same
> problem]
> RCSID: $Id: shp2pgsql.c,v 1.96 2005/08/29 22:36:25 strk Exp $
> RCSID: $Id: shp2pgsql.c,v 1.91 2005/07/04 09:47:03 strk Exp $
> So it seems that postgis 1.0.4 has the problem and not 1.0.3.
> Thanx for all the help!
>> Could you try to log two postgis compilation and send their here ?
>> I explain myself, to solve this problem I think that you could
>> download the postgis-1.0.4_p20050914.tar.gz tarball, then compile and
>> install it by hand (log the whole process and the result for your
>> importation). If that works then you've maybe add too much
>> compilation optimizations options (could you give what optimizations
>> you've used ?).
>> Then reemerge the postgis-1.0.4_p20050914.ebuild and log the whole
>> proccess (emerge -v postgis >& /tmp/emerge.log, rerun your
>> importation test.
>> Then I see what could I do to solve this, comparing both files.
>> Le 15 sept. 05 à 17:04, christomec a écrit :
>>> Unfotunetaly the data belong to a client and is also regarded as
>>> sensitive
>>> data.
>>> What I can't understand is the that it works on the suse
>>> installation
>>> (source) and not on the gentoo (emerge).
>>> suse:
>>> select version();
>>> PostgreSQL 8.0.3 on i686-pc-linux-gnu, compiled by GCC gcc (GCC)
>>> 3.3.5
>>> 20050117 (prerelease) (SUSE Linux)
>>> select postgis_full_version();
>>> POSTGIS="1.0.3" PROJ="Rel. 4.4.8, 3 May 2004" USE_STATS
>>> DBPROC="0.3.0"
>>> RELPROC="0.3.0"
>>> gentoo: [new install: postgis-1.0.4_p20050914.ebuild]
>>> select version();
>>> i686-pc-linux-gnu-gcc (GCC) 3.3.6 (Gentoo 3.3.6, ssp-3.3.6-1.0,
>>> pie-8.7.8)
>>> POSTGIS="1.1.0CVS" GEOS="2.1.4" PROJ="Rel. 4.4.9, 29 Oct 2004"
>>> USE_STATS
>>> DBPROC="0.3.1" RELPROC="0.3.1"
>>> gentoo: [previous install: postgis-1.0.1_p20050727-r1.ebuild]
>>> select version();
>>> pie-8.7.8)
>>> USE_STATS
>>>> Hi strk,
>>>> do you mean there is still a problem with the
>>>> postgis-1.0.4_p20050914.tar.gz tarball ?
>>>> Christo, please could you send here the problematic shapefile
>>>> please ? We could test it with 1.1.0CVS and the official 1.0.4 one.
>>>> Le 15 sept. 05 à 16:34, strk at refractions.net a écrit :
>>>>> On Thu, Sep 15, 2005 at 04:27:59PM +0200, christomec wrote:
>>>>>> I'm sorry, my mistake. I thought I had the use flags set in a
>>>>>> file
>>>>>> somewhere, but that was not the case. I'll try emerging again.
>>>>>> Could this
>>>>>> be why I'm still experiencing the same problems?
>>>>> GEOS and PROJ4 have nothing to do with loading shapefiles.
>>>>> Why don't you get the sources instead of fighting with package
>>>>> managers ? Belive me, that's where the meat is.
>>>>> --strk;
>>>>>>> Well ....
>>>>>>> I've just downloaded the lastest 1.0.4 version of postgis from
>>>>>>> postgis.org and I see that the shp2pgsql.c as the same date
>>>>>>> (2005/08/29 22:36:14) so the problem couldn't came from here I
>>>>>>> think.
>>>>>>> Concerning the geos and proj support you must set proj and
>>>>>>> geos in
>>>>>>> your USE flags, for more support information use emerge -pv
>>>>>>> postgis,
>>>>>>> here you've see all the support (red are supports enabled and
>>>>>>> blue
>>>>>>> are those disabled). To simplify you must reemerge postgis with
>>>>>>> the
>>>>>>> specified flags, for example you could simply use this command
>>>>>>> line :
>>>>>>> USE="proj geos" emerge -v postgis
>>>>>>> (or -pv to ensure that you'll effectively use geos and proj
>>>>>>> support).
>>>>>>> Hope that help.
>>>>>>> Le 15 sept. 05 à 15:37, christomec a écrit :
>>>>>>>> I have now emerged postgis-1.0.4_p20050914.ebuild, but it seems
>>>>>>>> that the
>>>>>>>> original problems weren't solved. Trying to import a shape file
>>>>>>>> still
>>>>>>>> fails.
>>>>>>>> trying:
>>>>>>>> shp2pgsql -c /tmp/streets.shp streets | psql -d dbname
>>>>>>>> ERROR:  unterminated quoted string at or near
>>>>>>>> "'010500000001000000010200000005000000D670917BBAA6394034BDC458A
>>>>>>>> 6E
>>>>>>>> 94
>>>>>>>> 0C0
>>>>>>>> 2C9ACE4E06A73940A911FA997AE940C0BEF561BD51A7394"
>>>>>>>> at character 292
>>>>>>>> LINE 1: ...TRAND','0687-0890-000','0687-0890-000_6TH
>>>>>>>> AVENUE','010500000...
>>>>>>>> and trying:
>>>>>>>> shp2pgsql -D /tmp/streets.shp streets dbname > /tmp/streets.sql
>>>>>>>> Shapefile type: Arc
>>>>>>>> Postgis type: MULTILINESTRING[2]
>>>>>>>> Segmentation fault
>>>>>>>> shp2pgsql
>>>>>>>> POSTGIS="1.1.0CVS" USE_STATS DBPROC="0.3.1" RELPROC="0.3.1"
>>>>>>>> Where is geos and proj4?
>>>>>>>> cat /etc/portage/package.keywords
>>>>>>>> dev-db/postgis ~x86
>>>>>>>> sci-libs/proj ~x86
>>>>>>>> sci-libs/geos ~x86
>>>>>>>>> Attached is a patch to bring shp2pgsql.c from Revision 1.91
>>>>>>>>> to Revision 1.96 (the one shipped with PostGIS 1.0.4).
>>>>>>>>> If you don't have the sources that's ... well ... sad :(
>>>>>>>>> You can still download latest release sources (1.0.4),
>>>>>>>>> run make in the loader/ directory and replace your dumper/
>>>>>>>>> loader
>>>>>>>>> with the newly created ones.
>>>>>>>>> .. you can read by the end of the patch all changes
>>>>>>>>> in shp2pgsql since 1.91 ...
>>>>>>>>> --strk;
>>>>>>>>> On Thu, Sep 15, 2005 at 12:28:25PM +0200, christomec wrote:
>>>>>>>>>> I get:
>>>>>>>>>> Is there a way of just fixing the shp2pgsql without having to
>>>>>>>>>> re-emerging
>>>>>>>>>> postgis?
>>>>>>>>>>> On Thu, Sep 15, 2005 at 11:58:29AM +0200,
>>>>>>>>>>> wrote:
>>>>>>>>>>>> On Thu, Sep 15, 2005 at 11:52:08AM +0200, christomec wrote:
>>>>>>>>>>>>> So is POSTGIS="1.1.0CVS" is in actual fact 1.0.3?
>>>>>>>>>>>> Might be, the 1.1 and 1.0 are two different branches in
>>>>>>>>>>>> CVS,
>>>>>>>>>>>> and 1.1.0CVS is there since about 1.0.0 is out...
>>>>>>>>>>>> there's no
>>>>>>>>>>>> easy way to tell which version of the code 1.1.0CVS is.
>>>>>>>>>>>> Since this is a bug with pgsql2shp what you should look at
>>>>>>>>>>>> is RCSID from it. It is shown running pgsql2shp w/out
>>>>>>>>>>>> arguments.
>>>>>>>>>>> Oops.. sorry, it's shp2pgsql (the loader), NOT pgsql2shp
>>>>>>>>>>> (the
>>>>>>>>>>> dumper).
>>>>>>>>>>> The RCSID is still shown when called w/out args
>>>>>>>>>>> --strk;
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> postgis-users mailing list
>>>>>>>>>>> postgis-users at postgis.refractions.net
>>>>>>>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-
>>>>>>>>>>> users
>>>>>>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>>> !DSPAM:43298a29104494037015152!
>> !DSPAM:432990ca131573838667129!
