[postgis-users] importing shape files nightmare!
christomec
christo at mecola.com
Fri Sep 16 05:35:49 PDT 2005
I'll see what I can do, testing your latest ebuild. I have another gentoo
box I can use.
I can't promise, but I'' try my best.
Thanx again for all the help guys!
> Hi,
> strange news ... but it make me thinking that the ebuild is not the
> problem.
> Yeasterday, after your mails, I've decided to make a new ebuild
> called postgis-1.0.4_p20050915.ebuild which is available as always on
> 01Map.net/gentoo/dev-db/postgis .
> This ebuild use the newest cvs version which contain some
> modifications which are listed on the official site : http://
> postgis.refractions.net/CVS.txt (all modifications made on 2005/09/15
> are used in this correponding tarball).
> It's the version corresponding to the official 1.0.4 one.
> Testers need.
> ps: this will not solve your problem cause it's version 1.0.4 but
> could you test it and then send us a strace (or some gdb ouotput) of
> your shp2pgsql command ?
> Le 16 sept. 05 à 12:49, christomec a écrit :
>> Problem solved.
>> We downloaded & installed the source:
>> postgresql-8.0.3.tar.gz
>> postgis-1.0.4.tar.gz
>> proj-4.4.9.tar.gz
>> geos-2.1.4.tar.bz2
>> Still experiencing the same issues, then we installed:
>> postgis-1.0.3.tar.gz
>> And then it worked.
>> No using:
>> RCSID: $Id: shp2pgsql.c,v 1.88.2.5 2005/07/27 02:47:06 strk Exp $
>> Was using: [both installed by prvious emerges, both giving the same
>> problem]
>> RCSID: $Id: shp2pgsql.c,v 1.96 2005/08/29 22:36:25 strk Exp $
>> RCSID: $Id: shp2pgsql.c,v 1.91 2005/07/04 09:47:03 strk Exp $
>> So it seems that postgis 1.0.4 has the problem and not 1.0.3.
>> Thanx for all the help!
>>> Could you try to log two postgis compilation and send their here ?
>>> I explain myself, to solve this problem I think that you could
>>> download the postgis-1.0.4_p20050914.tar.gz tarball, then compile and
>>> install it by hand (log the whole process and the result for your
>>> importation). If that works then you've maybe add too much
>>> compilation optimizations options (could you give what optimizations
>>> you've used ?).
>>> Then reemerge the postgis-1.0.4_p20050914.ebuild and log the whole
>>> proccess (emerge -v postgis >& /tmp/emerge.log, rerun your
>>> importation test.
>>> Then I see what could I do to solve this, comparing both files.
>>> Le 15 sept. 05 à 17:04, christomec a écrit :
>>>> Unfotunetaly the data belong to a client and is also regarded as
>>>> sensitive
>>>> data.
>>>> What I can't understand is the that it works on the suse
>>>> installation
>>>> (source) and not on the gentoo (emerge).
>>>> suse:
>>>> select version();
>>>> PostgreSQL 8.0.3 on i686-pc-linux-gnu, compiled by GCC gcc (GCC)
>>>> 3.3.5
>>>> 20050117 (prerelease) (SUSE Linux)
>>>> select postgis_full_version();
>>>> POSTGIS="1.0.3" PROJ="Rel. 4.4.8, 3 May 2004" USE_STATS
>>>> DBPROC="0.3.0"
>>>> RELPROC="0.3.0"
>>>> gentoo: [new install: postgis-1.0.4_p20050914.ebuild]
>>>> select version();
>>>> i686-pc-linux-gnu-gcc (GCC) 3.3.6 (Gentoo 3.3.6, ssp-3.3.6-1.0,
>>>> pie-8.7.8)
>>>> POSTGIS="1.1.0CVS" GEOS="2.1.4" PROJ="Rel. 4.4.9, 29 Oct 2004"
>>>> USE_STATS
>>>> DBPROC="0.3.1" RELPROC="0.3.1"
>>>> gentoo: [previous install: postgis-1.0.1_p20050727-r1.ebuild]
>>>> select version();
>>>> pie-8.7.8)
>>>> USE_STATS
>>>>> Hi strk,
>>>>> do you mean there is still a problem with the
>>>>> postgis-1.0.4_p20050914.tar.gz tarball ?
>>>>> Christo, please could you send here the problematic shapefile
>>>>> please ? We could test it with 1.1.0CVS and the official 1.0.4 one.
>>>>> Le 15 sept. 05 à 16:34, strk at refractions.net a écrit :
>>>>>> On Thu, Sep 15, 2005 at 04:27:59PM +0200, christomec wrote:
>>>>>>> I'm sorry, my mistake. I thought I had the use flags set in a
>>>>>>> file
>>>>>>> somewhere, but that was not the case. I'll try emerging again.
>>>>>>> Could this
>>>>>>> be why I'm still experiencing the same problems?
>>>>>> GEOS and PROJ4 have nothing to do with loading shapefiles.
>>>>>> Why don't you get the sources instead of fighting with package
>>>>>> managers ? Belive me, that's where the meat is.
>>>>>> --strk;
>>>>>>>> Well ....
>>>>>>>> I've just downloaded the lastest 1.0.4 version of postgis from
>>>>>>>> postgis.org and I see that the shp2pgsql.c as the same date
>>>>>>>> (2005/08/29 22:36:14) so the problem couldn't came from here I
>>>>>>>> think.
>>>>>>>> Concerning the geos and proj support you must set proj and
>>>>>>>> geos in
>>>>>>>> your USE flags, for more support information use emerge -pv
>>>>>>>> postgis,
>>>>>>>> here you've see all the support (red are supports enabled and
>>>>>>>> blue
>>>>>>>> are those disabled). To simplify you must reemerge postgis with
>>>>>>>> the
>>>>>>>> specified flags, for example you could simply use this command
>>>>>>>> line :
>>>>>>>> USE="proj geos" emerge -v postgis
>>>>>>>> (or -pv to ensure that you'll effectively use geos and proj
>>>>>>>> support).
>>>>>>>> Hope that help.
>>>>>>>> Le 15 sept. 05 à 15:37, christomec a écrit :
>>>>>>>>> I have now emerged postgis-1.0.4_p20050914.ebuild, but it seems
>>>>>>>>> that the
>>>>>>>>> original problems weren't solved. Trying to import a shape file
>>>>>>>>> still
>>>>>>>>> fails.
>>>>>>>>> trying:
>>>>>>>>> shp2pgsql -c /tmp/streets.shp streets | psql -d dbname
>>>>>>>>> ERROR: unterminated quoted string at or near
>>>>>>>>> "'010500000001000000010200000005000000D670917BBAA6394034BDC458A
>>>>>>>>> 6E
>>>>>>>>> 94
>>>>>>>>> 0C0
>>>>>>>>> 2C9ACE4E06A73940A911FA997AE940C0BEF561BD51A7394"
>>>>>>>>> at character 292
>>>>>>>>> LINE 1: ...TRAND','0687-0890-000','0687-0890-000_6TH
>>>>>>>>> AVENUE','010500000...
>>>>>>>>> and trying:
>>>>>>>>> shp2pgsql -D /tmp/streets.shp streets dbname > /tmp/streets.sql
>>>>>>>>> Shapefile type: Arc
>>>>>>>>> Postgis type: MULTILINESTRING[2]
>>>>>>>>> Segmentation fault
>>>>>>>>> shp2pgsql
>>>>>>>>> POSTGIS="1.1.0CVS" USE_STATS DBPROC="0.3.1" RELPROC="0.3.1"
>>>>>>>>> Where is geos and proj4?
>>>>>>>>> cat /etc/portage/package.keywords
>>>>>>>>> dev-db/postgis ~x86
>>>>>>>>> sci-libs/proj ~x86
>>>>>>>>> sci-libs/geos ~x86
>>>>>>>>>> Attached is a patch to bring shp2pgsql.c from Revision 1.91
>>>>>>>>>> to Revision 1.96 (the one shipped with PostGIS 1.0.4).
>>>>>>>>>> If you don't have the sources that's ... well ... sad :(
>>>>>>>>>> You can still download latest release sources (1.0.4),
>>>>>>>>>> run make in the loader/ directory and replace your dumper/
>>>>>>>>>> loader
>>>>>>>>>> with the newly created ones.
>>>>>>>>>> .. you can read by the end of the patch all changes
>>>>>>>>>> in shp2pgsql since 1.91 ...
>>>>>>>>>> --strk;
>>>>>>>>>> On Thu, Sep 15, 2005 at 12:28:25PM +0200, christomec wrote:
>>>>>>>>>>> I get:
>>>>>>>>>>> Is there a way of just fixing the shp2pgsql without having to
>>>>>>>>>>> re-emerging
>>>>>>>>>>> postgis?
>>>>>>>>>>>> On Thu, Sep 15, 2005 at 11:58:29AM +0200,
>>>>>>>>>>>> wrote:
>>>>>>>>>>>>> On Thu, Sep 15, 2005 at 11:52:08AM +0200, christomec wrote:
>>>>>>>>>>>>>> So is POSTGIS="1.1.0CVS" is in actual fact 1.0.3?
>>>>>>>>>>>>> Might be, the 1.1 and 1.0 are two different branches in
>>>>>>>>>>>>> CVS,
>>>>>>>>>>>>> and 1.1.0CVS is there since about 1.0.0 is out...
>>>>>>>>>>>>> there's no
>>>>>>>>>>>>> easy way to tell which version of the code 1.1.0CVS is.
>>>>>>>>>>>>> Since this is a bug with pgsql2shp what you should look at
>>>>>>>>>>>>> is RCSID from it. It is shown running pgsql2shp w/out
>>>>>>>>>>>>> arguments.
>>>>>>>>>>>> Oops.. sorry, it's shp2pgsql (the loader), NOT pgsql2shp
>>>>>>>>>>>> (the
>>>>>>>>>>>> dumper).
>>>>>>>>>>>> The RCSID is still shown when called w/out args
>>>>>>>>>>>> --strk;
>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>> postgis-users mailing list
>>>>>>>>>>>> postgis-users at postgis.refractions.net
>>>>>>>>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-
>>>>>>>>>>>> users
>>>>>>>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>> !DSPAM:432990ca131573838667129!
> !DSPAM:432ab044119201862618108!
