[postgis-users] PostGIS and Mapserver
Ezequias Rodrigues da Rocha ezequias at recife.pe.gov.br
Fri Sep 16 11:16:58 PDT 2005
i don't believe (and I checked) that there is a tcpip_socket on
Posgresql 8.0 so I didn't find this item here.
Ezequias
Randy James wrote:
>in your pg_hba.conf you need to give permission to use the connection and example
>in the file is like this
># host    all         all         127.0.0.1         255.255.255.255   trust
>in the postgresql.conf file enable the tcpic connection like this:
>tcpip_socket = true
>Your problems are postres problems not postgis or mapserver, look in your
>posgresql documents.
>--- Ezequias Rodrigues da Rocha <ezequias at recife.pe.gov.br> wrote:
>>but I can enter on the db via ssh connection.
>>This have any difference from entering via apache ?
>>Ezequias
>>Randy James wrote:
>>>looks like the error for the fix listed as number 4
>>>>Hi list,
>>>>I am trying to access postgis via mapserver (a cgi server) but the
>>>>resoult is allways a problem. Could anobody take a look on my problem ?
>>>>the stack trace is shown below:
>>>>msDrawMap(): Image handling error. Failed to draw layer named 'bairros'.
>>>>msPOSTGISLayerOpen(): Query error. couldnt make connection to DB with
>>>>connect string 'user=postgres password=pt dbname=db1
>>>>host=myserver.mydomain port=5432'.
>>>>Error reported was 'could not create socket: Permission denied '.
>>>>This error occured when trying to make a connection to the specified
>>>>postgresql server.
>>>>Most commonly this is caused by
>>>>(1) incorrect connection string
>>>>(2) you didnt specify a 'user=...' in your connection string
>>>>(3) the postmaster (postgresql server) isnt running
>>>>(4) you are not allowing TCP/IP connection to the postmaster
>>>>(5) your postmaster is not running on the correct port - if its not on
>>>>5432 you must specify a 'port=...'
>>>>(6) the security on your system does not allow the webserver (usually
>>>>user 'nobody') to make socket connections to the postmaster
>>>>(7) you forgot to specify a 'host=...' if the postmaster is on a
>>>>different machine
>>>>(8) you made a typo
>>>>My best regards
>>>>Ezequias
>>>>_______________________________________________
>>>>postgis-users mailing list
>>>>postgis-users at postgis.refractions.net
>>>>http://postgis.refractions.net/mailman/listinfo/postgis-users
>>>Yahoo! Mail - PC Magazine Editors' Choice 2005
>>>http://mail.yahoo.com
>__________________________________________________
>Do You Yahoo!?
>Tired of spam?  Yahoo! Mail has the best spam protection around
