[postgis-users] PostGIS and Mapserver
Randy James
rjames57 at yahoo.com
Fri Sep 16 11:36:39 PDT 2005
hmm well best bet is to read the manual at:
http://www.postgresql.org/docs/8.0/interactive/index.html
--- Ezequias Rodrigues da Rocha <ezequias at recife.pe.gov.br> wrote:
> i don't believe (and I checked) that there is a tcpip_socket on
> Posgresql 8.0 so I didn't find this item here.
> Ezequias
> Randy James wrote:
> >in your pg_hba.conf you need to give permission to use the connection and
> example
> >in the file is like this
> ># host all all 127.0.0.1 255.255.255.255 trust
> >in the postgresql.conf file enable the tcpic connection like this:
> >tcpip_socket = true
> >Your problems are postres problems not postgis or mapserver, look in your
> >posgresql documents.
> >>but I can enter on the db via ssh connection.
> >>This have any difference from entering via apache ?
> >>Ezequias
> >>Randy James wrote:
> >>>looks like the error for the fix listed as number 4
> >>>>Hi list,
> >>>>I am trying to access postgis via mapserver (a cgi server) but the
> >>>>resoult is allways a problem. Could anobody take a look on my problem ?
> >>>>the stack trace is shown below:
> >>>>msDrawMap(): Image handling error. Failed to draw layer named 'bairros'.
> >>>>msPOSTGISLayerOpen(): Query error. couldnt make connection to DB with
> >>>>connect string 'user=postgres password=pt dbname=db1
> >>>>host=myserver.mydomain port=5432'.
> >>>>Error reported was 'could not create socket: Permission denied '.
> >>>>This error occured when trying to make a connection to the specified
> >>>>postgresql server.
> >>>>Most commonly this is caused by
> >>>>(1) incorrect connection string
> >>>>(2) you didnt specify a 'user=...' in your connection string
> >>>>(3) the postmaster (postgresql server) isnt running
> >>>>(4) you are not allowing TCP/IP connection to the postmaster
> >>>>(5) your postmaster is not running on the correct port - if its not on
> >>>>5432 you must specify a 'port=...'
> >>>>(6) the security on your system does not allow the webserver (usually
> >>>>user 'nobody') to make socket connections to the postmaster
> >>>>(7) you forgot to specify a 'host=...' if the postmaster is on a
> >>>>different machine
> >>>>(8) you made a typo
> >>>>My best regards
> >>>>Ezequias
> >>>>_______________________________________________
> >>>>postgis-users mailing list
> >>>>postgis-users at postgis.refractions.net
> >>>>http://postgis.refractions.net/mailman/listinfo/postgis-users
> >>>Yahoo! Mail - PC Magazine Editors' Choice 2005
> >>>http://mail.yahoo.com
> >__________________________________________________
> >Do You Yahoo!?
> >Tired of spam? Yahoo! Mail has the best spam protection around
______________________________________________________
Yahoo! for Good
Donate to the Hurricane Katrina relief effort.
http://store.yahoo.com/redcross-donate3/
