[postgis-users] PostGIS and Mapserver
Ezequias Rodrigues da Rocha
ezequias at recife.pe.gov.br
Fri Sep 16 11:42:05 PDT 2005
Nice tip =-O
Randy James wrote:
>hmm well best bet is to read the manual at:
>http://www.postgresql.org/docs/8.0/interactive/index.html
>--- Ezequias Rodrigues da Rocha <ezequias at recife.pe.gov.br> wrote:
>>i don't believe (and I checked) that there is a tcpip_socket on
>>Posgresql 8.0 so I didn't find this item here.
>>Ezequias
>>Randy James wrote:
>>>in your pg_hba.conf you need to give permission to use the connection and
>>example
>>>in the file is like this
>>># host all all 127.0.0.1 255.255.255.255 trust
>>>in the postgresql.conf file enable the tcpic connection like this:
>>>tcpip_socket = true
>>>Your problems are postres problems not postgis or mapserver, look in your
>>>posgresql documents.
>>>>but I can enter on the db via ssh connection.
>>>>This have any difference from entering via apache ?
>>>>Ezequias
>>>>Randy James wrote:
>>>>>looks like the error for the fix listed as number 4
>>>>>>Hi list,
>>>>>>I am trying to access postgis via mapserver (a cgi server) but the
>>>>>>resoult is allways a problem. Could anobody take a look on my problem ?
>>>>>>the stack trace is shown below:
>>>>>>msDrawMap(): Image handling error. Failed to draw layer named 'bairros'.
>>>>>>msPOSTGISLayerOpen(): Query error. couldnt make connection to DB with
>>>>>>connect string 'user=postgres password=pt dbname=db1
>>>>>>host=myserver.mydomain port=5432'.
>>>>>>Error reported was 'could not create socket: Permission denied '.
>>>>>>This error occured when trying to make a connection to the specified
>>>>>>postgresql server.
>>>>>>Most commonly this is caused by
>>>>>>(1) incorrect connection string
>>>>>>(2) you didnt specify a 'user=...' in your connection string
>>>>>>(3) the postmaster (postgresql server) isnt running
>>>>>>(4) you are not allowing TCP/IP connection to the postmaster
>>>>>>(5) your postmaster is not running on the correct port - if its not on
>>>>>>5432 you must specify a 'port=...'
>>>>>>(6) the security on your system does not allow the webserver (usually
>>>>>>user 'nobody') to make socket connections to the postmaster
>>>>>>(7) you forgot to specify a 'host=...' if the postmaster is on a
>>>>>>different machine
>>>>>>(8) you made a typo
>>>>>>My best regards
>>>>>>Ezequias
>>>>>>_______________________________________________
>>>>>>postgis-users mailing list
>>>>>>postgis-users at postgis.refractions.net
>>>>>>http://postgis.refractions.net/mailman/listinfo/postgis-users
>>>>>Yahoo! Mail - PC Magazine Editors' Choice 2005
>>>>>http://mail.yahoo.com
>>>__________________________________________________
>>>Do You Yahoo!?
>>>Tired of spam? Yahoo! Mail has the best spam protection around
>______________________________________________________
>Yahoo! for Good
>Donate to the Hurricane Katrina relief effort.
>http://store.yahoo.com/redcross-donate3/
