[postgis-users] PostGIS and Mapserver
david techer davidtecher at yahoo.fr
Fri Sep 16 13:19:00 PDT 2005
Hum!
do you use and type the command
psql -d dbpostgis -U ....
to the ssh connection (terminal) or from your local machine?
if U want to find pg_ctl path do
which pg_ctl
or
pg_config --bindir
Ezequias Rodrigues da Rocha wrote:
> i don't believe (and I checked) that there is a tcpip_socket on
> Posgresql 8.0 so I didn't find this item here.
> Ezequias
> Randy James wrote:
>> in your pg_hba.conf you need to give permission to use the connection
>> and example
>> in the file is like this
>> # host    all         all         127.0.0.1         255.255.255.255
>> trust
>> in the postgresql.conf file enable the tcpic connection like this:
>> tcpip_socket = true
>> Your problems are postres problems not postgis or mapserver, look in
>> your
>> posgresql documents.
>> --- Ezequias Rodrigues da Rocha <ezequias at recife.pe.gov.br> wrote:
>>> but I can enter on the db via ssh connection.
>>> This have any difference from entering via apache ?
>>> Ezequias
>>> Randy James wrote:
>>>> looks like the error for the fix listed as number 4
>>>>> Hi list,
>>>>> I am trying to access postgis via mapserver (a cgi server) but the
>>>>> resoult is allways a problem. Could anobody take a look on my
>>>>> problem ?
>>>>> the stack trace is shown below:
>>>>> msDrawMap(): Image handling error. Failed to draw layer named
>>>>> 'bairros'.
>>>>> msPOSTGISLayerOpen(): Query error. couldnt make connection to DB
>>>>> with connect string 'user=postgres password=pt dbname=db1
>>>>> host=myserver.mydomain port=5432'.
>>>>> Error reported was 'could not create socket: Permission denied '.
>>>>> This error occured when trying to make a connection to the
>>>>> specified postgresql server.
>>>>> Most commonly this is caused by
>>>>> (1) incorrect connection string
>>>>> (2) you didnt specify a 'user=...' in your connection string
>>>>> (3) the postmaster (postgresql server) isnt running
>>>>> (4) you are not allowing TCP/IP connection to the postmaster
>>>>> (5) your postmaster is not running on the correct port - if its
>>>>> not on 5432 you must specify a 'port=...'
>>>>> (6) the security on your system does not allow the webserver
>>>>> (usually user 'nobody') to make socket connections to the postmaster
>>>>> (7) you forgot to specify a 'host=...' if the postmaster is on a
>>>>> different machine
>>>>> (8) you made a typo
>>>>> My best regards
>>>>> Ezequias
>>>>> _______________________________________________
>>>>> postgis-users mailing list
>>>>> postgis-users at postgis.refractions.net
>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>>> __________________________________ Yahoo! Mail - PC Magazine
>>>> Editors' Choice 2005 http://mail.yahoo.com
>> __________________________________________________
>> Do You Yahoo!?
>> Tired of spam?  Yahoo! Mail has the best spam protection around
>> http://mail.yahoo.com _______________________________________________
___________________________________________________________________________
Appel audio GRATUIT partout dans le monde avec le nouveau Yahoo! Messenger
Téléchargez cette version sur http://fr.messenger.yahoo.com
