[postgis-users] PostGIS and Mapserver
david techer davidtecher at yahoo.fr
Fri Sep 16 13:48:48 PDT 2005
strange?
if U can connect to postgresql locally by doing (without ssh!)
psql -d db1 -U postgres -h myserver.mydomain
and
by ssh
psql db1
it means that TCP/IP are allowed!
did U succeed by ssh connection to find pg_ctl by doing
which pg_ctl
then do
to find where is postgresql.conf doing
psql -d template1 -c "show data_directory"
then
replace
listen_adresses = 'localhost' by listen_adresses = '*'
then
`which pg_ctl` restart
let me know
Ezequias Rodrigues da Rocha wrote:
> from ssh terminal.
> Locally the problem does not occours too.
> see my steps
> ssh root at server
> password
> psql db1
> the psql prompt appears.
> Ezequias
> david techer wrote:
>> Hum!
>> do you use and type the command
>> psql -d dbpostgis -U ....
>> to the ssh connection (terminal) or from your local machine?
>> if U want to find pg_ctl path do
>> which pg_ctl
>> or
>> pg_config --bindir
>>> but I can enter on the db via ssh connection.
>>> This have any difference from entering via apache ?
>>> Ezequias
>>> Randy James wrote:
>>>> looks like the error for the fix listed as number 4
>>>> --- Ezequias Rodrigues da Rocha <ezequias at recife.pe.gov.br> wrote:
>>>>> Hi list,
>>>>> I am trying to access postgis via mapserver (a cgi server) but the
>>>>> resoult is allways a problem. Could anobody take a look on my
>>>>> problem ?
>>>>> the stack trace is shown below:
>>>>> msDrawMap(): Image handling error. Failed to draw layer named
>>>>> 'bairros'.
>>>>> msPOSTGISLayerOpen(): Query error. couldnt make connection to DB
>>>>> with connect string 'user=postgres password=pt dbname=db1
>>>>> host=myserver.mydomain port=5432'.
>>>>> Error reported was 'could not create socket: Permission denied '.
>>>>> This error occured when trying to make a connection to the
>>>>> specified postgresql server.
>>>>> Most commonly this is caused by
>>>>> (1) incorrect connection string
>>>>> (2) you didnt specify a 'user=...' in your connection string
>>>>> (3) the postmaster (postgresql server) isnt running
>>>>> (4) you are not allowing TCP/IP connection to the postmaster
>>>>> (5) your postmaster is not running on the correct port - if its
>>>>> not on 5432 you must specify a 'port=...'
>>>>> (6) the security on your system does not allow the webserver
>>>>> (usually user 'nobody') to make socket connections to the postmaster
>>>>> (7) you forgot to specify a 'host=...' if the postmaster is on a
>>>>> different machine
>>>>> (8) you made a typo
>>>>> My best regards
>>>>> Ezequias
>>>>> _______________________________________________
>>>>> postgis-users mailing list
>>>>> postgis-users at postgis.refractions.net
>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>>>        __________________________________ Yahoo! Mail - PC Magazine
>>>> Editors' Choice 2005 http://mail.yahoo.com
>> ___________________________________________________________________________
>> Appel audio GRATUIT partout dans le monde avec le nouveau Yahoo!
>> Messenger Téléchargez cette version sur http://fr.messenger.yahoo.com
Appel audio GRATUIT partout dans le monde avec le nouveau Yahoo! Messenger
