[postgis-users] PostGIS and Mapserver
Ezequias Rodrigues da Rocha ezequias at recife.pe.gov.br
Fri Sep 16 12:03:51 PDT 2005
Too strange. I didn't really not find the pg_ctl. Where is it ?
Ezequias
david techer wrote:
> strange?
> if U can connect to postgresql locally by doing (without ssh!)
> psql -d db1 -U postgres -h myserver.mydomain
> and
> by ssh
> psql db1
> it means that TCP/IP are allowed!
> did U succeed by ssh connection to find pg_ctl by doing
> which pg_ctl
> then do
> to find where is postgresql.conf doing
> psql -d template1 -c "show data_directory"
> then
> replace
> listen_adresses = 'localhost' by listen_adresses = '*'
> then
> `which pg_ctl` restart
> let me know
> Ezequias Rodrigues da Rocha wrote:
>> from ssh terminal.
>> Locally the problem does not occours too.
>> see my steps
>> ssh root at server
>> password
>> psql db1
>> the psql prompt appears.
>> Ezequias
>> david techer wrote:
>>> Hum!
>>> do you use and type the command
>>> psql -d dbpostgis -U ....
>>> to the ssh connection (terminal) or from your local machine?
>>> if U want to find pg_ctl path do
>>> which pg_ctl
>>> or
>>> pg_config --bindir
>>>> but I can enter on the db via ssh connection.
>>>> This have any difference from entering via apache ?
>>>> Ezequias
>>>> Randy James wrote:
>>>>> looks like the error for the fix listed as number 4
>>>>> --- Ezequias Rodrigues da Rocha <ezequias at recife.pe.gov.br> wrote:
>>>>>> Hi list,
>>>>>> I am trying to access postgis via mapserver (a cgi server) but
>>>>>> the resoult is allways a problem. Could anobody take a look on my
>>>>>> problem ?
>>>>>> the stack trace is shown below:
>>>>>> msDrawMap(): Image handling error. Failed to draw layer named
>>>>>> 'bairros'.
>>>>>> msPOSTGISLayerOpen(): Query error. couldnt make connection to DB
>>>>>> with connect string 'user=postgres password=pt dbname=db1
>>>>>> host=myserver.mydomain port=5432'.
>>>>>> Error reported was 'could not create socket: Permission denied '.
>>>>>> This error occured when trying to make a connection to the
>>>>>> specified postgresql server.
>>>>>> Most commonly this is caused by
>>>>>> (1) incorrect connection string
>>>>>> (2) you didnt specify a 'user=...' in your connection string
>>>>>> (3) the postmaster (postgresql server) isnt running
>>>>>> (4) you are not allowing TCP/IP connection to the postmaster
>>>>>> (5) your postmaster is not running on the correct port - if its
>>>>>> not on 5432 you must specify a 'port=...'
>>>>>> (6) the security on your system does not allow the webserver
>>>>>> (usually user 'nobody') to make socket connections to the postmaster
>>>>>> (7) you forgot to specify a 'host=...' if the postmaster is on a
>>>>>> different machine
>>>>>> (8) you made a typo
>>>>>> My best regards
>>>>>> Ezequias
>>>>>> _______________________________________________
>>>>>> postgis-users mailing list
>>>>>> postgis-users at postgis.refractions.net
>>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>>>>        __________________________________ Yahoo! Mail - PC
>>>>> Magazine Editors' Choice 2005 http://mail.yahoo.com
>>> ___________________________________________________________________________
>>> Appel audio GRATUIT partout dans le monde avec le nouveau Yahoo!
>>> Messenger Téléchargez cette version sur http://fr.messenger.yahoo.com
