[postgis-users] trying to debug segmentation violation
Jessica M Salmon
jmsalmon at fs.fed.us
Wed Sep 21 10:27:54 PDT 2005
Mark,
>Unfortunately an intermittent Signal 11 tends to indicate a hardware
problem, normally bad memory.
It is intermittent in that it happens only on a small percentage of the
data, but it happens very consistently only on these points. This suggests
to me that bad memory cannot be responsible. But I am downloading memtest86
to try tonight, just in case.
Thanks for your input.
-Meghan
"Mark
Cave-Ayland"
<m.cave-ayland at we To
bbased.co.uk> "'PostGIS Users Discussion'"
Sent by: <postgis-users at postgis.refractions.
postgis-users-bou net>
nces at postgis.refr cc
actions.net
Subject
RE: [postgis-users] trying to debug
09/21/2005 10:46 segmentation violation
AM
Please respond to
PostGIS Users
Discussion
stgis.refractions
.net>
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Jessica M Salmon
> Sent: 21 September 2005 17:04
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] trying to debug segmentation violation
> A plpsql function I wrote is starting to occasionally kick me
> off with a signal 11 error code. It seems to occur while
> calculating a 300m buffer around the transformed point
> transform(geomfromewkt('SRID=4326;POINT(-118.335235595703
> 36.8628845214844)', 102008) When I do this at the command
> line (from the same geometry in memory as the function was
> accessing), it gives a result just fine. The function
> calculates thousands upon thousands of these just fine, but
> objects to this one and one other.
> I have two questions:
> 1) How can I obtain more information on where exactly the
> segV is occurring? I know where it happens in my code, but
> since it seems to happen in a geos function, I cannot use
> print statements to get any more detail.
> 2) What are the common causes of this sort of error?
> Thanks for any responses,
> Meghan
Hi Meghan,
problem, normally bad memory. If you are using an x86 processor, then it's
worth letting memtest86 (http://www.memtest86.com/) run overnight to see if
it finds any errors, and if so, replace the faulty module and see if the
problem still occurs.
Kind regards,
Mark.
WebBased Ltd
South West Technology Centre
Tamar Science Park
Plymouth
PL6 8BT
T: +44 (0)1752 791021
F: +44 (0)1752 791023
W: http://www.webbased.co.uk
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
