[postgis-users] trying to debug segmentation violation
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Wed Sep 21 09:46:35 PDT 2005
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Jessica M Salmon
> Sent: 21 September 2005 17:04
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] trying to debug segmentation violation
> A plpsql function I wrote is starting to occasionally kick me
> off with a signal 11 error code. It seems to occur while
> calculating a 300m buffer around the transformed point
> transform(geomfromewkt('SRID=4326;POINT(-118.335235595703
> 36.8628845214844)', 102008)  When I do this at the command
> line (from the same geometry in memory as the function was
> accessing), it gives a result just fine. The function
> calculates thousands upon thousands of these just fine, but
> objects to this one and one other.
> I have two questions:
> 1) How can I obtain more information on where exactly the
> segV is occurring? I know where it happens in my code, but
> since it seems to happen in a geos function, I cannot use
> print statements to get any more detail.
> 2) What are the common causes of this sort of error?
> Thanks for any responses,
> Meghan
Hi Meghan,
Unfortunately an intermittent Signal 11 tends to indicate a hardware
problem, normally bad memory. If you are using an x86 processor, then it's
worth letting memtest86 (http://www.memtest86.com/) run overnight to see if
it finds any errors, and if so, replace the faulty module and see if the
problem still occurs.
Kind regards,
Mark.
WebBased Ltd
South West Technology Centre
Tamar Science Park
Plymouth
PL6 8BT
T: +44 (0)1752 791021
F: +44 (0)1752 791023
W: http://www.webbased.co.uk
