[postgis-users] data loading problem
Chris Everhart
chris_everhart at hotmail.com
Tue Sep 27 11:30:07 PDT 2005
Hello all,
I am having a problem loading data to a database. I am using a hosting
service that includes PostGIS and I have recently been moved to a different
server. When I run the command "psql -p 5434 -d BernaNM -f den_jeffZip.sql"
(den_jeffZip.sql was created with shp2pgsql), this is the output:
-jailshell-2.05b$ psql -p 5434 -d BernaNM -f den_jeffZip.sql
BEGIN
psql:den_jeffZip.sql:2: NOTICE: CREATE TABLE will create implicit sequence
"den_jeffzip_gid_seq" for serial column "den_jeffzip.gid"
CREATE TABLE
addgeometrycolumn
public.den_jeffzip.the_geom SRID:-1 TYPE:MULTIPOLYGON DIMS:2
geometry_column fixed:0
(1 row)
When I get into the database and do a "\d" command, the new table does not
show. Also, I did a "select * from geometry_columns;" command and the table
has not been updated. I've tried several SQL insert files that have worked
in the past and none have yielded any results.
Does the admin have to change any permissions on my account? Any other
suggestions?
Thanks people.
Christian
_________________________________________________________________
Is your PC infected? Get a FREE online computer virus scan from McAfee®
Security. http://clinic.mcafee.com/clinic/ibuy/campaign.asp?cid=3963
