[postgis-users] data loading problem
Mark Cave-Ayland
m.cave-ayland at webbased.co.uk
Wed Sep 28 01:37:34 PDT 2005
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Chris Everhart
> Sent: 27 September 2005 19:30
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] data loading problem
> Hello all,
> I am having a problem loading data to a database. I am using a hosting
> service that includes PostGIS and I have recently been moved to a
different
> server. When I run the command "psql -p 5434 -d BernaNM -f
den_jeffZip.sql"
> (den_jeffZip.sql was created with shp2pgsql), this is the output:
> -jailshell-2.05b$ psql -p 5434 -d BernaNM -f den_jeffZip.sql BEGIN
> psql:den_jeffZip.sql:2: NOTICE: CREATE TABLE will create
> implicit sequence
> "den_jeffzip_gid_seq" for serial column "den_jeffzip.gid" CREATE TABLE
> addgeometrycolumn
> public.den_jeffzip.the_geom SRID:-1 TYPE:MULTIPOLYGON DIMS:2
> geometry_column fixed:0 (1 row)
> When I get into the database and do a "\d" command, the new table does not
> show. Also, I did a "select * from geometry_columns;" command and the
table
> has not been updated. I've tried several SQL insert files that have
worked
> in the past and none have yielded any results.
> Does the admin have to change any permissions on my account? Any other
> suggestions?
> Thanks people.
> Christian
Hi Christian,
Looking at the output from your script, there appears to be a BEGIN tag but
no COMMIT tag - hence the server will not commit any changes. Can you check
to see that there is a COMMIT statement somewhere in your den_jeffZip.sql
file?
Also it could be that in moving server, you have been upgraded to a newer
version of PostGIS/PostgreSQL. If so, you may find that using the shp2pgsql
on your new server to regenerate your .sql files from your shapefiles may
give better results.
Kind regards,
Mark.
WebBased Ltd
South West Technology Centre
Tamar Science Park
Plymouth
PL6 8BT
T: +44 (0)1752 791021
F: +44 (0)1752 791023
W: http://www.webbased.co.uk
