[postgis-users] create a dataset with a name I already used before
Markus Schaber
schabi at logix-tt.com
Wed Sep 28 04:18:53 PDT 2005
Hi, Gregory,
Gregory S. Williamson wrote:
> Giorgio --
> When a table is created with a spatial geometry column, an reference is put into a table called "geometry_columns" -- this might be what is causing your problem as when a table is fropped the reference remains in this table. In postGIS 0.7 this table looks like:
> Column | Type | Modifiers
> f_table_catalog | character varying(256) | not null
> f_table_schema | character varying(256) | not null
> f_table_name | character varying(256) | not null
> f_geometry_column | character varying(256) | not null
> coord_dimension | integer | not null
> srid | integer | not null
> type | character varying(30) | not null
> attrelid | oid |
> varattnum | integer |
> stats | histogram2d |
> In 1.0 the table is similar but missing the last 3 columns.
AFAIR, the last three columns are obsolete if you run PostgreSQL >= 8.0,
but not with PostGIS 1.X on a 7.4 PostgreSQL server.
Markus
