[postgis-users] create a dataset with a name I already used before
Gregory S. Williamson gsw at globexplorer.com
Fri Sep 23 02:43:28 PDT 2005
Giorgio --
When a table is created with a spatial geometry column, an reference is put into a table called "geometry_columns" -- this might be what is causing your problem as when a table is fropped the reference remains in this table. In postGIS 0.7 this table looks like:
      Column       |          Type          | Modifiers
 f_table_catalog   | character varying(256) | not null
 f_table_schema    | character varying(256) | not null
 f_table_name      | character varying(256) | not null
 f_geometry_column | character varying(256) | not null
 coord_dimension   | integer                | not null
 srid              | integer                | not null
 type              | character varying(30)  | not null
 attrelid          | oid                    |
 varattnum         | integer                |
 stats             | histogram2d            |
In 1.0 the table is similar but missing the last 3 columns.
You might manually delete the references to your table using the f_table_name column.
If that doesn't work you might try posting back with postGIS version, platform and a more detailed description of the error you are seeing.
HTH,
Greg Williamson
DBA
GlobeXplorer LLC
-----Original Message-----
From:	postgis-users-bounces at postgis.refractions.net on behalf of Giorgio Plazzotta
Sent:	Fri 9/23/2005 2:16 AM
To:	postgis-users at postgis.refractions.net
Cc:
Subject:	[postgis-users] create a dataset with a name I already used before
 I apologize if the problem i am reporting has already been treated before.
When I delete a table in the PG database maybe there is some reference that
continue to refer to that name, in fact I cannot use that table name anymore
when I create another dataset.
What do I have to do?
Giorgio
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
!DSPAM:4333c53f228311393888631!
