[postgis-users] Re: Re: rasters in PostGIS...
Patrick pvanlaake at users.sourceforge.net
Fri Sep 30 00:46:17 PDT 2005
Hi Martin,
"Chapman, Martin" <MChapman at sanz.com> wrote in message
news:ED3A48B9840E594890A2BC172D11946502F9C0B1 at mailman.san.com...
> Please understand that comments were only meant to offer help.
I'd like to first apologize for my shrill tone in that previous post. It got
late, I was cranky. Sorry about that.
My main point in the in-or-out discussion is that whether the DB is GB
without or TB with raster data does not seem to be particularly relevant
because in both cases there are TBs of data that need loading, analysis, and
managing. In the enterprise environment where PostGIS is or could be
prominent (and that specifically excludes data powerhouses like EDC, GSFC,
USDA, and the commercial outfits) data will be accessed by multiple users
over a network. So from the point of view of hardware capacity, CPU load, or
network congestion there isn't too much of a difference.
What really speaks for putting raster data in a DB is the management of
access and concurrency, and the uniformity of interface. I am not thinking
of some static data warehousing here, but an active repository that is
frequently accessed for data analysis. In that case, where multiple users
are accessing and editing data, a layout that optimizes data access (by
tiling large datasets), prevents unauthorized access, and guards against
corruption due to multiple concurrent edits would be more than just a
trivial feature set.
Mind you that most raster formats are actually not optimally organized for
the typical analysis task. Whereas many spatial operators use a kernel of
data around the current pixel (e.g. the slope function) most formats store
data in rows. This is trivial on small files, but not so on larger files. If
rasters are to be implemented in PostGIS it will definitely have some form
of tiling, to optimize data management at the DB level. This opens up myriad
opportunities for optimized analysis (where an application does not need to
load large amount of data to work on a small section), mosaicking (e.g. all
SRTM tiles as a single raster), etc.
Backups and hardware failures? Yes, well, the latter is as much part of life
as hunger and death and it affects TB databases as badly as GB databases.
And I have been doing my backups incrementally for the last 10 years and
although I have never had to backup TBs of data I very much believe that
PG-Joe will find himself in the same situation.
Even if it is not for the USGS, I think that many users would welcome
rasters in PostGIS. Read the posts. But doing that right requires critical
review, so welcome aboard the PostGIS Raster Effort! {;-D
Cheers,
Patrick
