[postgis-users] postgis & php
Aaron Racicot
aaronr at ecotrust.org
Mon Apr 3 14:58:52 PDT 2006
Nelson,
Here is some code that I have from a project accessing postgis data from
PHP (using pgsql2shp):
// Now connect to the db
$host_str = "host=localhost";
$db_str = "dbname=foo_db";
$usr_str = "user=web_user";
$string = $host_str." ".$db_str." ".$usr_str;
$connection = pg_connect($string);
if (!$connection)
pg_close($connection);
echo "Error: Cannot connect to the database <br>\n";
else
echo "Connected to the database <br>\n";
//////////////////// Lots of code deleted... ////////////////////
// Create a view for the data needed...
$exec_str = sprintf("CREATE VIEW
".$previous_session_name."_".$previous_session_id." AS ".
"SELECT bk.the_geom, sum(tr.total_lbs*tb.percent)
as total_lbs ".
"FROM tow%02d_3kblk_intersect as tb, trawl%02d".
" as tr, cablk3km as bk, port as pt ".
"where tb.blk_gid=bk.gid ".$species_sql."
".$port_sql." ".$gear_sql.
" and tb.tow%02d_id=tr.tow_id2 ".
"GROUP BY bk.the_geom HAVING
count(tr.tow_id2)>2",$start_year_short,$start_year_short,$start_year_sho
rt);
echo $exec_str."<br>\n";
$result_pg_exec = pg_exec($connection, $exec_str);
if (!$result_pg_exec) {
printf("<B>%s</B><BR>\n", pg_errormessage());
// execute the pgsql2shp to create the output
echo " execute the pgsql2shp to create the output<br>";
$dir_exec = sprintf("/usr/local/pgsql/bin/pgsql2shp -u web_user -f
".$session_tmp_dir.
"data/target_areas/test_output.shp
shelf_closure_db ".
"\"SELECT * from
".$previous_session_name."_".$previous_session_id."\"");
echo $dir_exec."<br>\n";
exec($dir_exec,$arr,$err1);
// Write out the output from the psql command
for ($ii=0;$ii<count($arr);$ii++)
echo $arr[$ii]."<br>\n";
// Drop the view
$result_pg_exec = pg_exec($connection, "DROP VIEW
".$previous_session_name."_".$previous_session_id);
Hope this helps... One funky thing I found is that not every capability
available in normal SQL is available in the SQL fed to pgsql2shp, so I
tend to stick with creating views, dumping the contents, and then
dropping the view. Just my preference.
A
| Aaron Racicot | aaronr at ecotrust.org |
| GIS Programmer | 503.467.0759 |
| e c o t r u s t |
| Jean Vollum Natural Capital Center |
| 721 NW Ninth Avenue |
| Suite 200 |
| Portland, OR 97209 |
| www.ecotrust.org |
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Nelson Guda
Sent: Monday, April 03, 2006 2:00 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] postgis & php
On Apr 3, 2006, at 3:08 PM, Ries van Twisk wrote:
> Nelson Guda wrote:
>> Hi all,
>> I am relatively new to postgis. I've got a database up and
>> running, and have used much of the language already. I am
>> looking for a php protocol that can run shp2pgsql and pgsql2shp
>> so that i can use these functions via a web interface.
> You would beable to access this function by executing a shellcript. It
> would be nice to have a php classet ofcourse, but I think
> exsecuting these from a php shell would not be a problem.
> Ries
Yes, I think that is what I need, but i don't know how to code that.
Can anyone help or point me to a good tutorial?
thanks much,
nelsong
>> Unfortunately my understanding of programming languages is very
>> limited - mostly I have used postgis through pgadmin.
>> I found a set of php classes on the web that include a function
>> for shp2pgsql, but I cannot seem to get it working. I'll copy
>> those functions below. I don't understand what I might need to
>> change to make this work. Can anyone help me out with this?
>> Thanks much,
>> nelsong
>> <snip...... />
> Ries van Twisk
> Freelance Typo3 Developer
> email: ries at vantwisk.nl
> web: http://www.rvantwisk.nl/
> skype: callto://r.vantwisk
> postgis-users mailing list postgis-users at postgis.refractions.net
