[postgis-users] A bit of advice would be greatly appreciated
James G Wilkinson
jgw at alpinegeophysics.com
Wed Apr 5 14:30:52 PDT 2006
> You probably need to post the results of
> select postgis_full_version();
> and the explain on the select you posted below.
Whoops, I should have realized that this would be helpful. Of note, I
realize
that I a behind on versions here. Thanks for taking a look at this.
Regards,
Jim
beta4=# select postgis_full_version();
POSTGIS="0.9.1" GEOS="2.1.1" PROJ="Rel. 4.4.9, 29 Oct 2004" USE_STATS
DBPROC="0.0.1" RELPROC="0.0.1"
(1 row)
beta4=# EXPLAIN SELECT a.icell, a.jcell,
SUM(AREA(INTERSECTION(a.the_geom,b.the_geom)) /
b.area * area_fraction * AREA(TRANSFORM(b.the_geom,32768))) as area
from regular_grid a, plant_area b
WHERE b.the_geom && a.the_geom and
DISTANCE(a.the_geom,b.the_geom) = 0
GROUP BY a.icell, a.jcell
ORDER BY a.icell, a.jcell;
QUERY
PLAN
GroupAggregate (cost=7834473491.51..7835087937.70 rows=16352 width=543)
-> Sort (cost=7834473491.51..7834627021.30 rows=61411915 width=543)
Sort Key: a.icell, a.jcell
-> Nested Loop (cost=1344.52..7697000461.50 rows=61411915 width=543)
Join Filter: (("outer".the_geom && "inner".the_geom) AND
(distance("inner".the_geom, "outer".the_geom) = 0::double precision))
-> Seq Scan on plant_area b (cost=0.00..379664.42 rows=7511242
width=287)
-> Materialize (cost=1344.52..2083.04 rows=16352 width=256)
-> Seq Scan on regular_grid a (cost=0.00..769.52
(8 rows)
> James G Wilkinson wrote:
>> All,
>> I have been monitoring this forum for some time, and it has been
>> very helpful in my efforts. I have run into a problem that I simply
>> cannot seem to get a handle on. I have two spatial data sets:
>> regular_grid (gid integer, area double, icell integer, jcell integer,
>> the_geom geometry) and plant_area (gid integer, area double,
>> area_fraction double, the_geom geometry). regular_grid represents
>> a 36 km by 36 km set of grid cells (polygons) that covers the
>> continental United States and is about 10 MB in size. plant_area is
>> a polygon coverage that covers North America which contains
>> the area covered by a single plant species and is about 6 GB in
>> size (each polygon in plant_area is roughly on the order of
>> 4,000,000 square meters). Both coverages are in LAT/LON
>> coordinates. I am trying to perform the following:
>> CREATE TABLE intersect_results AS
>> AREA(TRANSFORM(b.the_geom,32768)))) as area
>> FROM regular_grid a, plant_area b
>> WHERE b.the_geom && a.the_geom AND
>> The TRANSFORM to 32768 gives me the area in square meters
>> in a Lambert Conformal Conic projection that I routinely use in my
>> work. Both tables are indexed using GIST on the geometries. I have
>> run VACUUM ANALYZE. I aborted the query on my Opteron
>> machine after 24 hours of CPU time (it was the only thing running).
>> I have not spent anytime trying to diagnose the query plan results
>> as I am almost completely ignorant of how to use them -- and maybe
>> this is the time to fix that gap in my knowledge. Regardless, I am
>> holding
>> out some hope that some expert on this list can provide some advice on
>> how better to render this query.
>> Regards,
>> terrakit
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060405/67f58adf/attachment.html>
