[postgis-users] A bit of advice would be greatly appreciated
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Apr 5 11:44:39 PDT 2006
James,
You probably need to post the results of
select postgis_full_version();
and the explain on the select you posted below.
-Steve
James G Wilkinson wrote:
> All,
> I have been monitoring this forum for some time, and it has been
> very helpful in my efforts. I have run into a problem that I simply
> cannot seem to get a handle on. I have two spatial data sets:
> regular_grid (gid integer, area double, icell integer, jcell integer,
> the_geom geometry) and plant_area (gid integer, area double,
> area_fraction double, the_geom geometry). regular_grid represents
> a 36 km by 36 km set of grid cells (polygons) that covers the
> continental United States and is about 10 MB in size. plant_area is
> a polygon coverage that covers North America which contains
> the area covered by a single plant species and is about 6 GB in
> size (each polygon in plant_area is roughly on the order of
> 4,000,000 square meters). Both coverages are in LAT/LON
> coordinates. I am trying to perform the following:
> CREATE TABLE intersect_results AS
> SELECT a.icell, a.jcell, SUM(AREA(INTERSECTION(a.the_geom,b.the_geom)) /
> b.area * area_fraction *
> AREA(TRANSFORM(b.the_geom,32768)))) as area
> FROM regular_grid a, plant_area b
> WHERE b.the_geom && a.the_geom AND
> DISTANCE(a.the_geom,b.the_geom) = 0
> GROUP BY a.icell, a.jcell
> ORDER BY a.icell, a.jcell;
> The TRANSFORM to 32768 gives me the area in square meters
> in a Lambert Conformal Conic projection that I routinely use in my
> work. Both tables are indexed using GIST on the geometries. I have
> run VACUUM ANALYZE. I aborted the query on my Opteron
> machine after 24 hours of CPU time (it was the only thing running).
> I have not spent anytime trying to diagnose the query plan results
> as I am almost completely ignorant of how to use them -- and maybe
> this is the time to fix that gap in my knowledge. Regardless, I am holding
> out some hope that some expert on this list can provide some advice on
> how better to render this query.
> Regards,
> terrakit
> postgis-users mailing list
