[postgis-users] shp2pgsql -I option
Paul Ramsey
pramsey at refractions.net
Wed Apr 5 22:44:49 PDT 2006
Brent,
No, checking the actual output of the command, it creates the spatial
index before loading the data... however, I am also using the -D
flag, so the whole batch is committed at once, which hopefully means
the index is batch created too, so no harm done...
shp2pgsql -D -I -i dra_tsa_clip.shp dra_tsa_clip | head -n 100 | less
BEGIN;
CREATE TABLE "dra_tsa_clip" (gid serial PRIMARY KEY,
"conf_id" int4,
"source" varchar(4),
"srcstate" varchar(19),
"resstate" varchar(10),
"road_id" int4,
"rd_seg_id" int4,
"region_id" int4,
"grid_code" int4);
SELECT AddGeometryColumn
('','dra_tsa_clip','the_geom','-1','MULTILINESTRING',2);
CREATE INDEX "dra_tsa_clip_the_geom_gist" ON "dra_tsa_clip" using
gist ("the_geom" gist_geome
try_ops);
COPY
"dra_tsa_clip" ("conf_id","source","srcstate","resstate","road_id","rd_s
eg_id","region_i
d","grid_code",the_geom) FROM stdin;
Unfortunately, when run without the -D flag, it still does the same
thing... this could result in some quite slow data loads, for people
who think that they are actually saving themselves time by using the -
I flag :)
shp2pgsql -I -i dra_tsa_clip.shp dra_tsa_clip | head -n 100 | less
BEGIN;
"conf_id" int4,
"road_id" int4,
"rd_seg_id" int4,
"region_id" int4,
"grid_code" int4);
try_ops);
On 5-Apr-06, at 10:33 PM, Brent Wood wrote:
> --- Paul Ramsey <pramsey at refractions.net> wrote:
>> I just ran using the -I option for the first time, and to my
>> surprise, the utility seemed to create the index *before* loading the
>> data...
> Hi Paul,
> Thanks for the pointer.
> It only creates the primary key, which, being a unique index,
> should be in
> place before any data is loaded, should it not?
> I can see why this is not really necessary if you can otherwise
> guarantee the
> uniqueness, but I think it is good practice to ensure any indices
> created to
> ensure data integrity (primary & foreign keys) are in place before
> any data is
> inserted.
> Indices which are only created for performance reasons may well be
> generated
> after the data is loaded, but I'm less comfortable about keys.
> Which means I (for one) am not unhappy about the perfromance hit
> from creating
> key indices before inserting data :-)
> Cheers,
> Brent
>> Bluejay:~/Desktop pramsey$ shp2pgsql -D -i -I dra_tsa_clip.shp
>> dra_tsa_clip | psql
>> Shapefile type: Arc
>> Postgis type: MULTILINESTRING[2]
>> BEGIN
>> NOTICE: CREATE TABLE will create implicit sequence
>> "dra_tsa_clip_gid_seq" for serial column "dra_tsa_clip.gid"
>> NOTICE: CREATE TABLE / PRIMARY KEY will create implicit index
>> "dra_tsa_clip_pkey" for table "dra_tsa_clip"
>> CREATE TABLE
>> addgeometrycolumn
>> public.dra_tsa_clip.the_geom SRID:-1 TYPE:MULTILINESTRING DIMS:2
>> (1 row)
>> <... no pause here ...>
>> CREATE INDEX
>> <... long pause here while data loads ...>
>> COMMIT
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
