[postgis-users] doesn't see postgresql
Paul Ramsey
pramsey at refractions.net
Sun Apr 9 08:35:01 PDT 2006
Er, assuming of course you are using packaged postgresql. If you are
not, make sure that either your ./bin pgsql directory is in your path
or that you give the pull page to pg_config when you run the ./
configure script.
On 9-Apr-06, at 8:33 AM, Paul Ramsey wrote:
> Make sure you have the postgresql-devel package installed.
> On 8-Apr-06, at 10:02 PM, Randy Burkhardt wrote:
>> Hi Steffen,
>> to install postgis-1.1.1, from a postgis-1.1.1 directory
>> # .configure
>> I get about the first 30 checks for things needed for postgis
>> successfully "..yes"
>> then
>> checking for pg_config... no
>> configure: error: PostgreSQL is required by PostGIS
>> On 4/8/06, Steffen Macke <sdteffen at gmail.com > wrote:Hello Randy,
>> > How can I get postgis to see I have postgresql-8.1.3 running?
>> What is the step where something is going wrong?
>> Do you get an error message?
>> I don't know much about Red Hat, but maybe you can simply install the
>> Fedora RPM(s):
>> http://postgis.refractions.net/rpms/fedora/fedora-core-4/
>> Regards,
>> Steffen
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
