[postgis-users] PostGIS' gentoo ebuild and PostGIS manual transalation
James Marca
jmarca at translab.its.uci.edu
Mon Apr 10 10:08:39 PDT 2006
At approximately Mon, Apr 10, 2006 at 12:22:38PM +0200, "R. Müller" wrote:
> nice to hear,
> but i actually can't find it... :-(
according to this page
http://packages.gentoo.org/ebuilds/?postgis-1.1.2
it isn't even being tested on the amd64 platform. However, I didn't
have any trouble manually ebuilding an earlier version, 1.1.0, on my
machine:
Linux 2.6.15-gentoo-r4 #2 PREEMPT Tue Feb 7 15:53:45 PST 2006 x86_64
AMD Athlon(tm) 64 Processor 3000+ AuthenticAMD GNU/Linux
using the x86 ebuild file. I can't test the new version until I
finish some development work, but I expect it will also build fine.
And I am using geos 2.2.1, from an unofficial ebuild I found reading
the Gentoo bugzilla logs. Probably from the same source noted in the
original email on this thread, but I do not recall the specifics.
* sci-libs/geos
Latest version available: 2.1.4
Latest version installed: 2.2.1
Size of downloaded files: 494 kB
Homepage: http://geos.refractions.net
Description: Geometry Engine - Open Source
License: GPL-2
Regards,
James Marca
> my gentoo says only (after sync) :
> $uname -a
> linux 2.6.14.2 #4 Thu Jan 26 10:08:45 CET 2006 x86_64 AMD Athlon(tm) 64
> $emerge -s postgis
> * dev-db/postgis
> Latest version available: 1.0.1_p20050805
> Latest version installed: [ Not Installed ]
> Size of downloaded files: 1,414 kB
> Homepage: http://postgis.refractions.net
> Description: Geographic Objects for PostgreSQL
> License: GPL-2
