[postgis-users] unexpected insert behavior
Kirk R. Wythers
kwythers at UMN.EDU
Wed Apr 12 11:33:16 PDT 2006
Thanks Brent, I've been trying to bother you to much, see inline
On Apr 12, 2006, at 1:25 PM, Brent Wood wrote:
> Hi Kirk,
> --- "Kirk R. Wythers" <kwythers at umn.edu> wrote:
>> To my mind this should insert a single row of tt_name = jack_pine and
>> cords = 21 into the cell with grid_id = 596524. However the below
>> SELECT statement shows that 16 rows were inserted.
> This insert will insert a single record into timber_volume for
> EVERY record
> already in timber volume. As there are 16 null records, the result
> is as
> expected. You can run the same select outside of the insert so you
> can see what
> it actually returns. The next iteration will return & insert 32
> records.....
> I suggest you use
> INSERT INTO timber_volume (grid_id, tt_id, year, cords, tv_id) SELECT
> 596524, 5, 1920, 21, NEXTVAL('timber_volume_seq') LIMIT 1 FROM
> timber_volume;
> The "LIMIT 1" should restrict it to just the one record, which I
> think is what
> you want if you use this approach.
> There are other ways to achieve the same result, but this should
> work OK.
I also "discovered" that the simple form of (without using SELECT):
INSERT INTO timber_volume (grid_id, tt_id, year, mbm, tv_id) VALUES
(596680, 10, 1920, 2, NEXTVAL('timber_volume_seq'));
also worked. I'll your LIMIT 1 approach a try as well. Nice to
understand why it was inserting all those records when I expected 1.
I've been playing around with views (trying to reduce the amount of
typing), but now that I seem to be able to enter data with the
command line, it is time to pick up PHP and figure out a more point
and click approach for students to use.
Thanks again,
Kirk
>> Can anyone see what I have done wrong that allowed caused 16 rows of
>> jack pine cords to be inserted when I was expected only 1 row?
> HTH...
> Brent
