[postgis-users] Querying MapServer PostGIS layer
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Apr 13 10:18:29 PDT 2006
The DBF files is limited by it's defining specification to 10 characters
for attribute column names.
Not sure I can help much more than that. You might want to cross post
his to the mapserver list as you will get a different (but overlapping)
collection of people that might be able to help.
-Steve
Dave Stone wrote:
> Thanks for that Steve. Would that it were that simple! I fell into that
> trap when converting the data-source from PostGIS to shapefile; I left
> the columns in lower-case. But the query template did display -- it just
> couldn't fill in table values because it didn't interpret the
> column-names as such. With the PostGIS layer I don't even get
> boiler-plate text showing on the page. The (abridged) template is:
> <!-- query template -->
> <html>
> <head>
> <title>MapServer - ItemQuery</title>
> </head>
> <body bgcolor="#ffffff">
> <font size="+2" face="arial,helvetica"><b>Case 1: Simple ItemQuery With
> QueryMap</b></font>
> <p>
> This is just a simple dump of a few attributes for an individual location
> in the test suites parishes layer:
> <p>
> <b>Place Name:</b> [placename]<br>
> <b>Qualifying Name:</b> [qualifyingname]<br>
> <b>Location Type:</b> [locationtype]<br>
> <b>Grid Reference:</b> [locationgridref]<br>
> <b>Religious Order:</b> [religiousorder]<br>
> <p>
> - - - - - - - etc.
> Is there a limit to the length of column names? I noticed that the above
> were truncated to 10 chars. by pgsql2shp. Any sources for debugging
> info? I've looked in the error logs, but they only seem to be recording
> parts of the app which (to my mind) are working.
> Thanks again,
> Dave
> Stephen Woodbridge wrote:
>> Dave,
>> Shapefile attribute columns are all UPPERCASE and Postgres/postgis
>> attribute columns are all lowercase so you need to make sure that the
>> reference to the attribute columns in your template match the case
>> expected by the data source.
>> -Steve W
>> Dave Stone wrote:
>>> Please excuse if this post has been asked before; I'm new to the list
>>> and finding it difficult to locate all the hidden gems of wisdom!
>>> I'm having a problem with querying a MapServer layer consisting of
>>> points stored in a PostGIS table. The plan is simple enough: I'm
>>> displaying the dots together with a boundary and an annotation layer,
>>> and I want to click on a dot and have a page come up showing
>>> non-spatial attributes from the PostGIS record for that location.
>>> What happens when I click a dot is I get a completely blank page
>>> titled 'MapServer Message' (but no message). The relevant bit of the
>>> MapServer .map file is:
>>> LAYER # query layer using the loccoords PostgreSQL table
>>> CONNECTIONTYPE postgis
>>> NAME saint_locations
>>> CONNECTION "user=erdb13 dbname=stdraft"
>>> DATA "geom from loccoords using unique locationref using
>>> srid=27700"
>>> STATUS ON
>>> DEBUG ON
>>> TYPE POINT
>>> TOLERANCE 25
>>> CLASS
>>> NAME "Locations"
>>> MINSCALE 2000000
>>> TEMPLATE "result.html"
>>> DEBUG ON
>>> STYLE
>>> SYMBOL "circle"
>>> SIZE 5
>>> COLOR 255 0 0
>>> OUTLINECOLOR 0 0 0
>>> END
>>> END
>>> This whole idea is based on an example in the MapServer tutorial
>>> (http://hypnos.cbs.umn.edu/tutorial/section3.html, choose Ex.3.1).
>>> The example works fine, so why doesn't my version? The answer seems
>>> to be that the layer being queried in the example is a shapefile
>>> whereas mine is in PostGIS. To test this suspicion, I amended the
>>> layer definition in the .map file as follows:
>>> # CONNECTIONTYPE postgis
>>> # CONNECTION "user=erdb13 dbname=stdraft"
>>> DATA "/var/www/html/saints/data/parish/locs"
>>> STATUS ON
>>> 'locs' is a shapefile produced by dumping (with pgsql2shp) the
>>> 'loccoords' table in the first DATA statement above.
>>> With only this trivial change, the query template 'result.html' works
>>> as intended. But since I want to use the PostGIS functionality, I
>>> need to find out what's wrong with the first LAYER spec. above.
>>> Any suggestions most gratefully received,
>>> Dave
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
