[postgis-users] Querying MapServer PostGIS layer
Paul Ramsey
pramsey at refractions.net
Thu Apr 13 19:37:44 PDT 2006
Dave,
Turn on statement logging in your PostgreSQL installation and see
what SQL mapserver is sending to the back-end. That may clarify
where/why things are failing a little. Also, what Mapserver version
are you using?
P
On Apr 13, 2006, at 8:34 AM, Dave Stone wrote:
> Thanks for that Steve. Would that it were that simple! I fell into
> that trap when converting the data-source from PostGIS to
> shapefile; I left the columns in lower-case. But the query template
> did display -- it just couldn't fill in table values because it
> didn't interpret the column-names as such. With the PostGIS layer I
> don't even get boiler-plate text showing on the page. The
> (abridged) template is:
> <!-- query template -->
> <html>
> <head>
> <title>MapServer - ItemQuery</title>
> </head>
> <body bgcolor="#ffffff">
> <font size="+2" face="arial,helvetica"><b>Case 1: Simple ItemQuery
> With QueryMap</b></font>
> <p>
> This is just a simple dump of a few attributes for an individual
> location
> in the test suites parishes layer:
> <p>
> <b>Place Name:</b> [placename]<br>
> <b>Qualifying Name:</b> [qualifyingname]<br>
> <b>Location Type:</b> [locationtype]<br>
> <b>Grid Reference:</b> [locationgridref]<br>
> <b>Religious Order:</b> [religiousorder]<br>
> <p>
> - - - - - - - etc.
> Is there a limit to the length of column names? I noticed that the
> above were truncated to 10 chars. by pgsql2shp. Any sources for
> debugging info? I've looked in the error logs, but they only seem
> to be recording parts of the app which (to my mind) are working.
> Thanks again,
> Dave
> Stephen Woodbridge wrote:
>> Dave,
>> Shapefile attribute columns are all UPPERCASE and Postgres/postgis
>> attribute columns are all lowercase so you need to make sure that
>> the reference to the attribute columns in your template match the
>> case expected by the data source.
>> -Steve W
>> Dave Stone wrote:
>>> Please excuse if this post has been asked before; I'm new to the
>>> list and finding it difficult to locate all the hidden gems of
>>> wisdom!
>>> I'm having a problem with querying a MapServer layer consisting
>>> of points stored in a PostGIS table. The plan is simple enough:
>>> I'm displaying the dots together with a boundary and an
>>> annotation layer, and I want to click on a dot and have a page
>>> come up showing non-spatial attributes from the PostGIS record
>>> for that location.
>>> What happens when I click a dot is I get a completely blank page
>>> titled 'MapServer Message' (but no message). The relevant bit of
>>> the MapServer .map file is:
>>> LAYER # query layer using the loccoords PostgreSQL table
>>> CONNECTIONTYPE postgis
>>> NAME saint_locations
>>> CONNECTION "user=erdb13 dbname=stdraft"
>>> DATA "geom from loccoords using unique locationref
>>> using srid=27700"
>>> STATUS ON
>>> DEBUG ON
>>> TYPE POINT
>>> TOLERANCE 25
>>> CLASS
>>> NAME "Locations"
>>> MINSCALE 2000000
>>> TEMPLATE "result.html"
>>> DEBUG ON
>>> STYLE
>>> SYMBOL "circle"
>>> SIZE 5
>>> COLOR 255 0 0
>>> OUTLINECOLOR 0 0 0
>>> END
>>> END
>>> This whole idea is based on an example in the MapServer tutorial
>>> (http://hypnos.cbs.umn.edu/tutorial/section3.html, choose Ex.
>>> 3.1). The example works fine, so why doesn't my version? The
>>> answer seems to be that the layer being queried in the example is
>>> a shapefile whereas mine is in PostGIS. To test this suspicion,
>>> I amended the layer definition in the .map file as follows:
>>> # CONNECTIONTYPE postgis
>>> # CONNECTION "user=erdb13 dbname=stdraft"
>>> DATA "/var/www/html/saints/data/parish/locs"
>>> STATUS ON
>>> 'locs' is a shapefile produced by dumping (with pgsql2shp) the
>>> 'loccoords' table in the first DATA statement above.
>>> With only this trivial change, the query template 'result.html'
>>> works as intended. But since I want to use the PostGIS
>>> functionality, I need to find out what's wrong with the first
>>> LAYER spec. above.
>>> Any suggestions most gratefully received,
>>> Dave
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
