[postgis-users] Re: problem to install 1.1.2 on AIX
Paolo De Simone
pdesimone at infocall.it
Wed Apr 19 06:22:28 PDT 2006
thanks for suggestion!!!
it was fundamental.
i have installed postgis1.1.2
thankyou
Patricio Cifuentes Ithal
paolo
>installing geos 2...
>Ingeniero en Informática
>Informática
>SIIGSA
>(56-2) 204 60 22
>----- Original Message -----
>From: "Paolo De Simone" <pdesimone at infocall.it>
>To: <postgis-users at postgis.refractions.net>
>Sent: Tuesday, April 18, 2006 11:26 AM
>Subject: [postgis-users] problem to install 1.1.2 on AIX
>> Hello all,
>> i'm trying to install PostGIS 1.1.2
>> over PostgreSQL 8.1.3
>> on AIX 5.2 RISC 6000
>> the steps
>> - gmake
>> - gmake install
>> are OK
>> but when run
>> psql -f lwpostgis.sql -d myDB
>> had the following result :
>> BEGIN
>> psql:/usr/local/postgresql8_1_3/pgsql/share/lwpostgis.sql:45: NOTICE:
>type
>> "histogram2d" is not yet defined
>> DETAIL: Creating a shell type definition.
>> psql:/usr/local/postgresql8_1_3/pgsql/share/lwpostgis.sql:45: ERROR:
>could
>> not load library "/usr/local/postgresql8_1_3/pgsql/lib/liblwgeom.so":
>Cannot
>> run a file that does not have a valid format.
>> psql:/usr/local/postgresql8_1_3/pgsql/share/lwpostgis.sql:50: ERROR:
>> current transaction is aborted, commands ignored until end of transaction
>> block
>> psql:/usr/local/postgresql8_1_3/pgsql/share/lwpostgis.sql:58: ERROR:
>> block
>> psql:/usr/local/postgresql8_1_3/pgsql/share/lwpostgis.sql:3358: ERROR:
>> block
>> ROLLBACK
>> Many thanks to anybody that can help me.
>> Greetings
>> paolo
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
