[postgis-users] Multiple instances of postgres.exe, Geoserver hangs
Craig Miller
craig.miller at spatialminds.com
Tue Aug 1 11:29:28 PDT 2006
I've seen this happen when the firewall isn't configured properly. The one
time I saw it was after I installed ZoneAlarm. I'm not too big a fan of
ZoneAlarm, so I just switched to my usual firewall and it immediately
corrected the problem.
--Craig
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of GPS
Blaster
Sent: Monday, July 31, 2006 1:06 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Multiple instances of postgres.exe, Geoserver hangs
Hi!
We have a problem with Geoserver, PostGIS and MapBuilder.
Our map displays fine, but we noticed a lot of instances of postgres.exe in
the task manager, simultaneously, mapbuilder fails to refresh some layers,
let's say street layer, that were showing, 20 or 30 seconds later you pan
the map and then street layer are not anymore shown.
We're not sure what causes the problem.
Is Geoserver requesting too many connections? (we test it from only one
client and still dozens of postgres.exe instances)?
Is Postgres.exe refusing more connections as a result of the many instances?
Could it be a driver / connector problem?
Thanks !
View this message in context:
http://www.nabble.com/Multiple-instances-of-postgres.exe%2C-Geoserver-hangs-
tf2026138.html#a5571600
Sent from the PostGIS - User forum at Nabble.com.
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
