[postgis-users] distance to coastline
Kevin Russell
krussell1 at baldwinmutual.com
Tue Aug 1 11:37:34 PDT 2006
In trying to learn more about gis by solving a problem, I've come up
with the following problem: how to compute the distance from a point
to the coastline. So first off, I installed postgis and after a
little looking I've found the following sources of data for the
entire us coastline: http://coastalmap.marine.usgs.gov/GISdata/
basemaps/coastlines/nos80k/ and then a smaller portion: http://
rimmer.ngdc.noaa.gov/mgg/coast/getcoast.html.
Because of my lack of experience, I figured the best way to get the
data into postgis was to convert the shapefile of the entire us
coastline and import it into postgis. I was successful in doing this
but it appears that all of the data is contained in one record, so
I'm assuming this is just a massive multipolygon. So I've got the
data, but now I'm stuck on getting the distance to the coastline as
distance_spheroid will not compute from point to multipolygon. Also,
I was unable to find a way to find the closest point on the
multipolygon so I can use distance_spheroid(point,point).
My other option is to import the second datasource which provides the
following data options: mapgen, arc/info ungenerate, matlab, or
splus. Here's a sample of the data:
# -b
-88.872153 30.052031
-88.871126 30.050930
-88.870393 30.050564
-88.870099 30.050710
-88.870099 30.051004
-88.871786 30.052104
# -b
-88.869439 30.049024
-88.869293 30.048730
-88.869073 30.048804
-88.868999 30.049024
-88.868999 30.049244
-88.869366 30.049464
# -b
-88.872373 30.048437
-88.872006 30.048144
-88.871346 30.047924
-88.870319 30.047997
-88.869733 30.047997
-88.869293 30.047850
-88.868633 30.047704
-88.867166 30.047704
-88.866872 30.047997
-88.867019 30.048510
-88.868119 30.049610
-88.868046 30.049170
-88.867753 30.048877
-88.867753 30.048657
-88.868193 30.048437
-88.869879 30.048510
-88.870686 30.048730
-88.871346 30.048730
-88.871786 30.048730
# -b
-88.872153 30.044990
-88.871053 30.045137
-88.870539 30.045137
-88.870246 30.044917
-88.870539 30.044623
-88.870979 30.044550
-88.871859 30.044550
-88.872299 30.044623
-88.872520 30.044843
And I'm assuming these are line segments. I think this will be the
easier option( less mathematically challenging) but am unable to
figure out how to get the data imported into postgis. Can anyone
please provide me some guidance? Then, once the data is in, what
would be the easiest way to find the closest point to utilize
distance_spheroid?
Thanks,
Kevin
