[postgis-users] Multiple instances of postgres.exe, Geoserver hangs
Paul Ramsey pramsey at refractions.net
Fri Aug 4 09:04:05 PDT 2006
That's the way PostgreSQL works, one process per connection, with shared
memory segment for interprocess communications, plus one master process
to create child processes as new connections come in.
P
Mario Servin wrote:
> Hi,
> I have noted in all versions of PostgreSQL (for Windows) that
> always there is more than one instance of postgreql.exe running. Though
> I have had no problem always catched my attention this strange
> behavior..., does anybody know why is this happening?
> On 7/31/06, *GPS Blaster* <gps.blaster at gmail.com
> <mailto:gps.blaster at gmail.com>> wrote:
>     Hi!
>     We have a problem with Geoserver, PostGIS and MapBuilder.
>     Our map displays fine, but we noticed a lot of instances of
>     postgres.exe in
>     the task manager, simultaneously, mapbuilder fails to refresh some
>     layers,
>     let's say street layer, that were showing, 20 or 30 seconds later
>     you pan
>     the map and then street layer are not anymore shown.
>     We're not sure what causes the problem.
>     Is Geoserver requesting too many connections? (we test it from only one
>     client and still dozens of postgres.exe instances)?
>     Is Postgres.exe refusing more connections as a result of the many
>     instances?
>     Could it be a driver / connector problem?
>     Thanks !
>     View this message in context:
>     http://www.nabble.com/Multiple-instances-of-postgres.exe%2C-Geoserver-hangs-tf2026138.html#a5571600
>     <http://www.nabble.com/Multiple-instances-of-postgres.exe%2C-Geoserver-hangs-tf2026138.html#a5571600>
>     Sent from the PostGIS - User forum at Nabble.com <http://Nabble.com>.
>     _______________________________________________
>     postgis-users mailing list
>     postgis-users at postgis.refractions.net
>     <mailto:postgis-users at postgis.refractions.net>
>     http://postgis.refractions.net/mailman/listinfo/postgis-users
