[postgis-users] Multiple instances of postgres.exe, Geoserver hangs
Mario Servin mservin at gmail.com
Fri Aug 4 06:54:24 PDT 2006
I have noted in all versions of PostgreSQL (for Windows) that always there
is more than one instance of postgreql.exe running. Though I have had no
problem always catched my attention this strange behavior..., does anybody
know why is this happening?
On 7/31/06, GPS Blaster <gps.blaster at gmail.com> wrote:
> Hi!
> We have a problem with Geoserver, PostGIS and MapBuilder.
> Our map displays fine, but we noticed a lot of instances of postgres.exein
> the task manager, simultaneously, mapbuilder fails to refresh some layers,
> let's say street layer, that were showing, 20 or 30 seconds later you pan
> the map and then street layer are not anymore shown.
> We're not sure what causes the problem.
> Is Geoserver requesting too many connections? (we test it from only one
> client and still dozens of postgres.exe instances)?
> Is Postgres.exe refusing more connections as a result of the many
> instances?
> Could it be a driver / connector problem?
> Thanks !
> http://www.nabble.com/Multiple-instances-of-postgres.exe%2C-Geoserver-hangs-tf2026138.html#a5571600
> Sent from the PostGIS - User forum at Nabble.com.
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060804/6ce2eb03/attachment.html>
