[postgis-users] shp2pgsql: Where are x,y-coordinates stored?
David William Bitner bitner at gyttja.org
Mon Aug 7 18:09:05 PDT 2006
Try v.in.ogr with postgis
http://grass.itc.it/grass60/manuals/html60_user/v.in.ogr.html
On 8/7/06, H.Lekin <h.lekin at gmx.net> wrote:
> Seems rather impossible to reply properly to the all-in-one digest; hope
> it looks OK:
> > well, does your shapefile contain coordinates? If it doesn't, then you
> > will have to create them. See the postgis documentation for the syntax
> > for retrieving geometry.
> The shapefile contains coordinates, as does PostgreSQL/PostGIS after
> importing the shapefile. I can access the latter via QGIS and it is
> displayed correctly.
> For GRASS' v.in.db I have to specify the x,y column names, what QGIS
> seems to do automatically. I listed the geometry_colums attributes. The
> table looks exactly like stated in the PostGIS Manual (which I do not
> find too helpful yet), but does not contain x,y coordinates.
> Meanwhile I found the OpenGIS Simple Features Specification For SQL Rev
> 1.1 - http://www.opengeospatial.org/docs/99-049.pdf -, where Chapters
> 2.2 and 3.1.4.2 look promising as well as really complicated.
> It would be very helpful and time saving, if s.b. could roughly outline
> the basic steps how to access x,y coordinates.
> Many thanks,
> H.L.
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060807/8d79869c/attachment.html>
