[postgis-users] combine 2 columns into geometry column
Donal Regan donal_regan10 at yahoo.co.uk
Mon Aug 7 22:49:55 PDT 2006
Hello.
What is the quickest way to combine 2 columns x and y into a single geometry column of type point?
Do I send the output of "select x,y from mytable" to a file (xy.out), then edit that file so that it each line has something like "INSERT INTO mytable (the_geom) VALUES (GeomFromText('POINT( 136.143781,35.816411 )',-1));" and then run
psql -d mydb -f xy.out
Is there a quicker way?
Cheers.
 Try the all-new Yahoo! Mail . "The New Version is radically easier to use" – The Wall Street Journal
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060808/e24f2965/attachment.html>
