[postgis-users] RE: getting non-latlon extent as lat/lon
Steve Benzo
steve_benzo at yahoo.com
Tue Aug 8 06:49:13 PDT 2006
It looks like we're on the right track towards getting an aggregated lat/lon from a non lat/lon EPSG'd table. The one issue I'm getting when running that command Mark, is an "Input geometry has unknown (-1) SRID"
I've checked geometry_columns and the table in question does have an EPSG code assigned to it, so I dunno...
Thoughts?
SB
ERROR: Input geometry has unknown (-1) SRID
In statement:
SELECT AsText(transform(extent(the_geom), 4326)) FROM tablex;
Geometry_columns
public tablex 2 26917 MULTIPOLYGON
On Sat, 2006-08-05 at 05:03 -0700, Steve Benzo wrote:
> Ok, that seems to get me a bunch of lat/lon coordinates, but how do I
> translate those into an extent then? Thanks.
> SB
Hi Steve,
How about something like this:
SELECT AsText(transform(extent(the_geom), 4326) FROM geomtable;
Note that since extent() is an aggregate it will scan the entire table
to produce the overall extent which can be slow on larger tables; you
may like to consider using the estimated_extent() function if you need
to do this interactively as part of an application.
Kind regards,
Mark.
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060808/236ad006/attachment.html>
