[postgis-users] Re: SRID for USA_Lambert_Conformal_Conic
P Kishor
punkish at eidesis.org
Sat Aug 19 21:48:45 PDT 2006
Well, after a few hours of bouncing around on websites, and scanning
through rows after rows of similar looking srtext, I give up. I can't
figure out the srid, auth_name, auth_srid, and proj4text for the
following srtext --
PROJCS[
'USA_Contiguous_Lambert_Conformal_Conic',
GEOGCS[
'GCS_North_American_1983',
DATUM[
'D_North_American_1983',
SPHEROID['GRS_1980',6378137.0,298.257222101]
PRIMEM['Greenwich',0.0],
UNIT['Degree',0.0174532925199433]
PROJECTION['Lambert_Conformal_Conic'],
PARAMETER['False_Easting',0.0],
PARAMETER['False_Northing',0.0],
PARAMETER['Central_Meridian',-96.0],
PARAMETER['Standard_Parallel_1',33.0],
PARAMETER['Standard_Parallel_2',45.0],
PARAMETER['Latitude_Of_Origin',39.0],
UNIT['Meter',1.0]
-19071146.8131673 -17820932.1267064 61.0351561931566;0 100000;0 100000
Any help would be much appreciated as it would stop me for committing
harm to my dell.
On 8/19/06, P Kishor <punkish at eidesis.org> wrote:
> Right then. So, I have to insert an entry for my SRS in the
> spatial_ref_sys table. Actually, I am surprised something like
> "USA_Contiguous_Lambert_Conformal_Conic" is not already there... I was
> assuming this was one of the common USA projections.
> In any case, I have the srtext nonsense. How do I "discover" the srid,
> auth_name, auth_srid, and proj4text for it? I am assuming I can't just
> make stuff up here.
> Follow-up question -- when I am able to add a row to the
> spatial_ref_sys table, then what? Do I have to actually transform
> (project) my datasets into this projection, and store them like that,
> or do I apply this projection on the fly whenever I do any SQL
> operation on them?
> On 8/19/06, Dylan Beaudette <dylan.beaudette at gmail.com> wrote:
> > ja.
> > > > Do you have any of the parameters associated with the Lambert
> > > > conformal conic projection? You will need these in order to add an
> > > > entry to the spatial_ref_sys table, with a custom SRID.
> > > Well, I do have the entire SRTEXT. Is that what you meant?
> > > > you can get more information on your original file with a tool like ogrinfo .
> > > > Cheers,
> > > > > Actually, I should explain this a bit further --
> > > > > (a) I had a Shapefile in USA_Lambert_Conformal_Conic that I imported
> > > > > into PostGIS using the shp2pgsql, psql dance. Whatever I did, its SRID
> > > > > is set to -1.
> > > > > (b) I created another dataset from lon/lat explicitly setting its SRID to 4326.
> > > > > Of course, now I can't do any geometrical analysis on these two
> > > > > because they are in different spatial references. Ideally, I want to
> > > > > convert my (b) dataset, the points that are in 4326, to the same srs
> > > > > as (a) dataset, namely USA_Lambert_Conformal_Conic.
> > > > > Hence my question.
> > > > > Many thanks in advance.
> > > > > > This is a topic I know very little about. Where do I learn more about
> > > > > > SRIDs, and more specifically,
> > > > > > 1. how do I find SRID for USA_Lambert_Conformal_Conic; and
> > > > > > 2. use that to change a dataset (project? is that the word wrt SRIDs?)
> Puneet Kishor http://punkish.eidesis.org/
> Nelson Inst. for Env. Studies, UW-Madison http://www.ies.wisc.edu/
> Open Source Geospatial Foundation https://edu.osgeo.org/
