[postgis-users] Re: SRID for USA_Lambert_Conformal_Conic
Dylan Lorimer edylan at google.com
Sat Aug 19 22:52:16 PDT 2006
You take a look here?
http://www.inovagis.org/giserver/epsg.asp
On 8/19/06, P Kishor <punkish at eidesis.org> wrote:
> Well, after a few hours of bouncing around on websites, and scanning
> through rows after rows of similar looking srtext, I give up. I can't
> figure out the srid, auth_name, auth_srid, and proj4text for the
> following srtext --
> PROJCS[
>   'USA_Contiguous_Lambert_Conformal_Conic',
>   GEOGCS[
>     'GCS_North_American_1983',
>     DATUM[
>       'D_North_American_1983',
>       SPHEROID['GRS_1980',6378137.0,298.257222101]
>     PRIMEM['Greenwich',0.0],
>     UNIT['Degree',0.0174532925199433]
>   PROJECTION['Lambert_Conformal_Conic'],
>   PARAMETER['False_Easting',0.0],
>   PARAMETER['False_Northing',0.0],
>   PARAMETER['Central_Meridian',-96.0],
>   PARAMETER['Standard_Parallel_1',33.0],
>   PARAMETER['Standard_Parallel_2',45.0],
>   PARAMETER['Latitude_Of_Origin',39.0],
>   UNIT['Meter',1.0]
> -19071146.8131673 -17820932.1267064 61.0351561931566;0 100000;0 100000
> Any help would be much appreciated as it would stop me for committing
> harm to my dell.
> > Right then. So, I have to insert an entry for my SRS in the
> > spatial_ref_sys table. Actually, I am surprised something like
> > "USA_Contiguous_Lambert_Conformal_Conic" is not already there... I was
> > assuming this was one of the common USA projections.
> > In any case, I have the srtext nonsense. How do I "discover" the srid,
> > auth_name, auth_srid, and proj4text for it? I am assuming I can't just
> > make stuff up here.
> > Follow-up question -- when I am able to add a row to the
> > spatial_ref_sys table, then what? Do I have to actually transform
> > (project) my datasets into this projection, and store them like that,
> > or do I apply this projection on the fly whenever I do any SQL
> > operation on them?
> > On 8/19/06, Dylan Beaudette <dylan.beaudette at gmail.com> wrote:
> > > ja.
> > > > > Do you have any of the parameters associated with the Lambert
> > > > > conformal conic projection? You will need these in order to add an
> > > > > entry to the spatial_ref_sys table, with a custom SRID.
> > > > Well, I do have the entire SRTEXT. Is that what you meant?
> > > > > you can get more information on your original file with a tool
> like ogrinfo .
> > > > > Cheers,
> > > > > > Actually, I should explain this a bit further --
> > > > > > (a) I had a Shapefile in USA_Lambert_Conformal_Conic that I
> imported
> > > > > > into PostGIS using the shp2pgsql, psql dance. Whatever I did,
> its SRID
> > > > > > is set to -1.
> > > > > > (b) I created another dataset from lon/lat explicitly setting
> its SRID to 4326.
> > > > > > Of course, now I can't do any geometrical analysis on these two
> > > > > > because they are in different spatial references. Ideally, I
> want to
> > > > > > convert my (b) dataset, the points that are in 4326, to the same
> srs
> > > > > > as (a) dataset, namely USA_Lambert_Conformal_Conic.
> > > > > > Hence my question.
> > > > > > Many thanks in advance.
> > > > > > > This is a topic I know very little about. Where do I learn
> more about
> > > > > > > SRIDs, and more specifically,
> > > > > > > 1. how do I find SRID for USA_Lambert_Conformal_Conic; and
> > > > > > > 2. use that to change a dataset (project? is that the word wrt
> SRIDs?)
> > Puneet Kishor http://punkish.eidesis.org/
> > Nelson Inst. for Env. Studies, UW-Madison http://www.ies.wisc.edu/
> > Open Source Geospatial Foundation https://edu.osgeo.org/
> postgis-users mailing list
E. Dylan Lorimer
Sales Engineer
Google Earth Enterprise
650.253.2459 (Office)
650.862.6810 (Mobile)
650.644.0182 (Fax)
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060819/243a1bd1/attachment.html>
