[postgis-users] Re: SRID for USA_Lambert_Conformal_Conic
Stephen Woodbridge
woodbri at swoodbridge.com
Sun Aug 20 10:12:05 PDT 2006
Good questions, I'm not sure I know the answer, but if you create new
tables with the correct srid and then do something like:
insert into new_table (select setsrid(the_geom), ...
-or-
insert into new_table (select transform(the_geom, 4326), ...
Then this should be a non issues. I think you are correct that you want
to keep you geometry_columns table up to date.
-Steve
P Kishor wrote:
> Thanks Steve.
> On 8/20/06, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
>> 1) a table say abc the has data the is already in this projection but
>> the srid=-1, for this table:
>> update abc set the_geom=setsrid(the_geom, 102005);
> Table 'abc' was created by importing a Shapefile via the shp2pgsql |
> psql dance. This shapefile was already in the correct projection, but
> on import into PostGIS, its SRID was set to -1 (my bad). So, to
> confirm what you are suggesting -- all I have to do for this one is to
> SetSRID() as you mention above. Should I not also update the
> geometry_columns entry for this table with the correct SRID (102005)
> or will the above UPDATE command do that for me?
>> and another table say def that has data in srid=4326
>> update table def set the_geom=transform(the_geom, 102005);
> Table 'def' was created by importing lon/lat data, adding geometry,
> and making points (what you suggested to someone else in another
> thread -- works brilliantly). This table was explicitly set to
> SRID=4326. Hence, the Transform() makes sense here. But, once again,
> should I not also update the geometry_columns entry for this table
> also with the correct SRID (102005) or will the above UPDATE command
> do that for me?
> Many thanks,
