[postgis-users] Postgis Java Geometry classes/Hibernate, borken query[Solution]
Dave Potts
dave.potts at pinan.co.uk
Fri Dec 1 12:06:13 PST 2006
Dave Potts wrote:
> Hi Folks
> I am using hibernate to query a postgis database.
> The majority of my distance queries work as expected, one does not!
> For one distance setting I get loads of answers, for a greater
> distance, I get none, when I would expect to get at least the first set.
> So I suspect that either Hibernate or Postgis are having problems.
> I can type the query in by hand and it works as expected , so I don't
> suspect the database or postgis interface to the database.
> Is there any debug code in postgres/postgi/Hibernate that will actual
> allow me work out what data is being sent from postgres to hibernate,
> what hibernate is caching and what its forwarding to the end user.
> regards David
> postgis-users mailing list
I found the problem, my hibernate query said something like
blah blah blah manor.geometry is not null and distance(manor.geometry,
srcCastle.geometry) < :distance
I was setting the value of distance by saying
query.setString("distance","3000");
Distance is a numerical construct
as soon as I said
query.setInteger("distance",3000);
It now works as expected !
Its at times like this, I remeber Pascal and its very rigid views about
argument types.
It has taken some 7 hours to find this problem.
David.
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20061201/300bf9df/attachment.vcf>
