[postgis-users] Fast access to PostGIS from c/c++
Boehm, Andreas boehm at rif.fuedo.de
Wed Dec 6 01:48:23 PST 2006
Hi Mark,
thanks for your advice.
> If all your geometries are of one type, e.g. points, the
> second fastest method would probably be to use a prepared
> statement using the MakePoint() function [...]
Using libpqxx prepared functionality with MakePoint() works fine.
Unfortunately is slower than inserting with GeometryFromText().
> In theory, COPY should be fastest method of inserting
> geometries since it requires that the client should already
> have converted the geometry to EWKB format ready for
> insertion.
I'll figure that out and post the results if somebody is interested in
it.
Regards
Andi
