[postgis-users] Re: Proposed SQL interface for PGRaster
Patrick pvanlaake at users.sourceforge.net
Tue Dec 5 11:17:13 PST 2006
"Stephen Marshall" <smarshall at wsi.com> wrote in message
news:4575AEDC.5030506 at wsi.com...
>I have written a proposal for the SQL interface to PGRaster, a raster-in-DB
>implementation.  The document can be found on the PostGIS Wiki at
> http://postgis.refractions.net/support/wiki/index.php?PgRasterSqlInterface
Hi Steve,
That looks like fine piece of work. Thanks for the effort.
After (rather cursory) reading of the pages I have two immediate points of
attention:
1. There is no mention yet of any kind of tiling or compression of the data.
Rasters are easily larger than a page size and some form of design has to be
applied to it, because the default TOAST approach is clearly too slow and
the same goes for the lo_ interface IIRC.
2. IMHO rasters are a logical collation of thematically related data sharing
a common geometry (regular tesselation and CRS). The data itself is
organized in raster bands, where each raster has 1 or more raster bands.
This concept is immediately obvious for satellite imagery, but the TIFF
format also uses a similar concept for instance. Such a design adds a level
of flexibility at the application level and most software already supports
this design. The raster band has a certain data type and a single raster can
have bands with different data types. The resolution of the pixels can
either be fixed at the level of the raster (all bands having the same
resolution) or at the level of the raster band. The latter situation is of
course more flexible and some satellite imagery has this characteristics
(e.g. Landsat ETM+ data, ASTER data), but it complicates indexing and
processing of data (e.g. extracting and sending a cube of data to, say, R
for processing). Up for debate, I'd say.
Cheers,
Patrick
