[postgis-users] 1.2.0 Release
Paul Ramsey
pramsey at refractions.net
Fri Dec 8 19:02:39 PST 2006
Nope, you got the right one, we forgot to bump the version numbers. I
have overwritten a new file with the correct version numbers.
P
On 8-Dec-06, at 6:18 PM, Carl Anderson wrote:
> Did I grab the wrong file?
> gis=# select postgis_full_version();
> POSTGIS="1.1.7" GEOS="3.0.0rc2-CAPI-1.3.0" PROJ="Rel. 4.4.9, 29 Oct
> 2004" USE_STATS
> (1 row)
> 1.2.0 seems to report as 1.1.7
> C.
> Paul Ramsey wrote:
>> http://postgis.refractions.net/download
>> The 1.2.0 release of PostGIS is now available. This is a major new
>> feature release, with the first PostGIS support for "curve" types,
>> and initial support for the ISO SQL/MM suite of spatial database
>> functions. Over time, the 1.2.X series will elaborate on the basic
>> support provided in this release:
>> * New Curve type, based on the ISO SQL/MM model for curves.
>> * Index binding for curves, allowing them to use the same R-
>> Tree indexes as the other types.
>> * Serialization and deserialization functions for Curve,
>> allowing them to be dumped and restored.
>> * Performance shortcuts for Contains and Within to optimize
>> point-in-polygon case.
>> * Support for most of the ST_* and SE_* spatial SQL functions
>> used by the ESRI ArcSDE spatial SQL interfaces.
>> * Documentation of the new SQL/MM functions and Curve types.
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
