[postgis-users] 1.2.0 Release
Carl Anderson carl.anderson at vadose.org
Fri Dec 8 19:34:14 PST 2006
Paul,
It looks good now.
Some of those performance enhancements make some of my routines much -
much faster  :)
As always thanks.
C.
Paul Ramsey wrote:
> Nope, you got the right one, we forgot to bump the version numbers. I
> have overwritten a new file with the correct version numbers.
> P
> On 8-Dec-06, at 6:18 PM, Carl Anderson wrote:
>> Did I grab the wrong file?
>> gis=# select postgis_full_version();
>> POSTGIS="1.1.7" GEOS="3.0.0rc2-CAPI-1.3.0" PROJ="Rel. 4.4.9, 29 Oct
>> 2004" USE_STATS
>> (1 row)
>> 1.2.0 seems to report as 1.1.7
>> C.
>> Paul Ramsey wrote:
>>> http://postgis.refractions.net/download
>>> The 1.2.0 release of PostGIS is now available. This is a major new
>>> feature release, with the first PostGIS support for "curve" types,
>>> and initial support for the ISO SQL/MM suite of spatial database
>>> functions. Over time, the 1.2.X series will elaborate on the basic
>>> support provided in this release:
>>>     * New Curve type, based on the ISO SQL/MM model for curves.
>>>     * Index binding for curves, allowing them to use the same R-Tree
>>> indexes as the other types.
>>>     * Serialization and deserialization functions for Curve,
>>> allowing them to be dumped and restored.
>>>     * Performance shortcuts for Contains and Within to optimize
>>> point-in-polygon case.
>>>     * Support for most of the ST_* and SE_* spatial SQL functions
>>> used by the ESRI ArcSDE spatial SQL interfaces.
>>>     * Documentation of the new SQL/MM functions and Curve types.
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
