[postgis-users] SpatialEJB3: (PostGIS and Hibernate)
Norman Barker nbarker at ittvis.com
Tue Dec 12 00:54:45 PST 2006
Glad you like the idea!  PostGIS does all the work though :-), and there
have been some good bug reports and questions from users as well.
In conclusion;
There have been quite a few users of the EJB3 Geometry annotations, but
they are split between JBoss users, and pure Hibernate/Spring users - it
works well in either environment.  Since it is possible to mark a
property of an entity as @Geometry and then have it persist and retrieve
from PostGIS then the investigation was a success, and I am using it in
more projects (and once my current deadlines are out of the way, I want
to do some more to the codebase).
The incorporation of spatial functions into hql and ejb-ql is I believe
the next step, but quite a major undertaking.  Certainly at the moment
you could achieve the same functionality with
entitymanager.createNativeQuery for example (which I use to run vacuum
analyze).
Let me know if you have any questions, and do post more details about
your project, there have been some interesting use cases.
Thanks,
Norman
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Andrew Hughes
Sent: 12 December 2006 04:39
To: PostGIS Users Discussion
Subject: [postgis-users] SpatialEJB3: (PostGIS and Hibernate)
Hello All,
I would like to use the SpatialEJB3 JBoss container for my JBoss Web
Service.
The SpatialEJB3 [
http://postgis.refractions.net/support/wiki/index.php?SpatialEJB3 ]
seems to be exactly what I want, but I do have some concerns before I
invest some time in this.....
*	Was there a conclusion to the SpatialEJB3 Investigation:
"Spatial EJB3 is a quick investigation to see if it is possible to
integrate the Java 5 annotation approach to mark a property of an object
as spatial and to delegate to the EJB3 persistence model to store and
retrieve this data."?
*	I require the PostGIS functions [such as
intersects(geometry,geometry)] to extract the data I am looking for in
my spatial database. I am unable to find a reference to any java code
that shows someone running anything [like select
intersection(my_geom,geometry) from locations_table where
intersects(my_geom,geomtery); ] ?
For the people who are involved in the Spatial EJB3, I really like the
idea... well-done!!!
--AH
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20061212/fcb17cf4/attachment.html>
