[postgis-users] Fast access to PostGIS from c/c++
Boehm, Andreas
boehm at rif.fuedo.de
Tue Dec 12 05:02:30 PST 2006
Hi Markus,
sorry to be slow in replying. I got distracted by other issues
yesterday.
> Why does the Tablewriter not work? Can you give us the code
> example, and the error message? We've used COPY to fill lots
> of geometry tables over here.
Here is my code to insert points with tablewriter:
void InsertPointsTableWriter(connection &c)
work *t = new work(c, "insert_points");
tablewriter *w = new tablewriter(*t, POINTS_TABLE);
vector<string> myData;
myData.resize(2);
srand(42);
double x, y;
for (int i = 0; i < POINT_COUNT;)
x = ((double) rand() + ((double) rand() / RAND_MAX))
/ (RAND_MAX + 1) * X_MAX;
y = ((double) rand() + ((double) rand() / RAND_MAX))
/ (RAND_MAX + 1) * Y_MAX;
myData[0] = to_string(i);
myData[1] = "GeometryFromText('POINT(" + to_string(x) + " "
+ to_string(y) + ")', -1)";
w->insert(myData);
// every 10000 points complete writing, start a new transaction
if (++i % 10000 == 0)
w->complete();
delete w;
t->commit();
delete t;
cerr << ".";
// Complete writing
w->complete();
delete w;
t->commit();
delete t;
cerr << "#";
The error message is:
SQL error: ERROR: parse error - invalid geometry
CONTEXT: COPY points, line 1, column geom:
"GeometryFromText('POINT(122.072
9172.53)', -1)"
Query was: '[END COPY]'
Running "INSERT INTO points VALUES (1, GeometryFromText('POINT(122.072
9172.53)', -1));" in pgAdmin was sucsessful.
Regards,
Andi
