[postgis-users] New Curve Types in 1.2
Ken Southerland
southerland at samsix.com
Tue Dec 12 13:36:26 PST 2006
This is very exciting news for us as we are just about to implement
curves/arcs in our application. I was just about to write code that would
store meta data to translate line strings into arcs/curves. But now maybe I
don't have to.
Is there any other documentation specific to the new curve types? I see brief
mention of them in the html documentation accompanying the source code.
Specifically I see the following line ...
COMPOUNDCURVE((0 0, 1 1, 1 0),(1 0, 0 1)
...as an example of a mixed curve/straight line sequence. First off, I'm
assuming it is missing a closed parantheses at the end of the string. In
other words, I'm assuming it should read ...
COMPOUNDCURVE((0 0, 1 1, 1 0),(1 0, 0 1))
... but then a further question I have is how this is read. I'm assuming that
this means there is an arc defined by the 3 points in the first set of
parantheses and then a short straight line sequence followed by the two
points defined in the second set. But how is this determined? What if I had
a 3-point LineString definition in the second part? How does the
CompoundCurve know that I meant a straight line sequence and not a
CicularString sequence?
Also, are there java classes yet written to handle these, like the LineString
class found in the java/jdbc/src/org/postgis/ subdirectory?
Also, is it true that only circular arcs are currently implemented? What is
the outlook for more complex curves like a Bezier curve?
Cheers! I'm very thrilled with this news!
Ken
------s----a----m----s----i----x------
Ken Southerland
Senior Consultant
Sam Six, Inc.
503-236-4288
http://www.samsix.com
