[postgis-users] New Curve Types in 1.2
Arnaud Lesauvage
thewild at freesurf.fr
Tue Dec 12 14:10:53 PST 2006
Ken Southerland a écrit :
> Specifically I see the following line ...
> COMPOUNDCURVE((0 0, 1 1, 1 0),(1 0, 0 1)
> ...as an example of a mixed curve/straight line sequence. First off, I'm
> assuming it is missing a closed parantheses at the end of the string. In
> other words, I'm assuming it should read ...
> COMPOUNDCURVE((0 0, 1 1, 1 0),(1 0, 0 1))
Maybe the left parenthesis is the error. Then you would read :
((0 0, 1 1, 1 0), 1 0, 0 1)
Then three points between parentheses make a curve, and points
outside are segments vertices ?
Just a guess.
I found this : http://www.wiscorp.com/2CD1R1-03-spatial-2001-12.pdf
but I was too lazy to read it ! ;)
Arnaud
