[postgis-users] To OID or not to OID?
Bruce Rindahl
rindahl at lrcwe.com
Thu Dec 14 12:15:54 PST 2006
I am creating and populating a table with X and Y values as attributes.
After the table is created I will add a geometry column and populate it with
points from the X and Y attributes. My question is what is the better
approach? Something like this?
CREATE TABLE wells
receipt varchar(8),
utm_x float8,
utm_y float8
WITH OIDS;
SELECT AddGeometryColumn('','wells','the_geom','26913','POINT',2);
Or the method used by shp2pgsql?
CREATE TABLE wells
gid serial PRIMARY KEY,
receipt" varchar(8),
utm_x" numeric,
utm_y" numeric
In the first method the oid field becomes the primary key where in the
second method the gid field becomes the primary key.
Is there a performance difference?
Thanks
Bruce Rindahl
